1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "make" for Windows 7 64-bit
To: [email protected], Mark Rivers <[email protected]>
Date: Tue, 7 Jun 2011 10:03:57 -0500
Hi Mark,
For future reference, this change has been committed to the R3.14 branch as
revision 12247, and will eventually appear in any R3.14.12.2 release.
- Andrew
On 2011-06-07 Mark Rivers wrote:
> Hi Andrew,
> Thanks very much for figuring this out.
> Once I removed that rule from RULES_BUILD then I was able to build EPICS
> modules using the latest MinGW\bin\mingw32-make.exe with no problems.  I
> tested on both win32-x86 and windows-x64.
> So both GnuWin make and MinGW "make" now work fine with that change.
> Mark
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Monday, June 06, 2011 4:57 PM
> To: Mark Rivers
> Cc: [email protected]; Benjamin Franksen; Matt Newville
> Hi Mark,
> On 2011-06-06 Mark Rivers wrote:
> > And I just made sure that this problem is not confined to the seq
> > snapshot, this problem of treating C files as C++ file happens in other
> > EPICS modules as well.
> Hmm, I see one possibility: Edit configure/RULES_BUILD and comment out
> this pattern rule on lines 208-211:
> %$(OBJ): %.C
> 	@$(HDEPENDS_CMD)
> 	@$(RM) $@
> 	$(COMPILE.cpp) $(call PATH_FILTER,$<) $(COMPILE_FILTER.cpp)
> That's using an upper-case letter C in the source pattern, which was one
> of the Unix conventions for C++ code which is useless on Windows and MacOS
> X.  I don't think we need that rule any more, so I think it we can remove it
> if necessary.
> - Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
RE: "make" for Windows 7 64-bit Mark Rivers
Prev: RE: "make" for Windows 7 64-bit Mark Rivers
Next: Re: Dynamic images in BOY Paweł Prędki
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Problem with caget on 3.14.12.1? Mark Rivers
