1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Request for opinions about device driver/support
To: "Gurd Pamela EXT" <[email protected]>, <[email protected]>
Date: Wed, 8 Jun 2011 13:44:13 -0400
Hello Pam,
I have done similar work on GE-IP cPCI ICS-710 . I’m using longout records for  num_ai_chans” and “num_samples”, ao record for “sample_rate”.
Initialization of these parameters can be done either by calling an initialization function or by setting ‘PINI’ field of the record to ‘YES’ and ‘VAL’ field to your desired value. For experimental purpose, I always use ‘PINI’ and ‘VAL’ for the initialization (edit them in the final .db file).
For my ICS-710 driver, I intended to fix num_ai_chans” to the maximum channels of the board because changing the number of channels requires me to reset the board to recalibrate its ADC chips. If your digitizer doesn’t require recalibration after changing the number of channels, you may change it by its associated EPICS record.
Good luck!
Yong
From: [email protected] [mailto:[email protected]] On Behalf Of Gurd Pamela EXT
Sent: Wednesday, June 08, 2011 11:38 AM
To: [email protected]
Subject: Request for opinions about device driver/support
Here at ITER, a driver has been developed to interface to the channels of the NI PXI 6259 board, which has
binary input and output, analog input and output and waveform data capabilities.  In order for the analog
input records to provide data, several parameters must be initialized:
“num_ai_chans”, “sample_rate”, “num_samples”.
Also, the “channel_type” must be set up for each record.
In the ITER implementation, each of these parameters is initialized by using an EPICS record.  I am not familiar with another driver that works that way.  Is this a common practice of which I'm not aware? Are there advantages or disadvantages?
My own feeling on this is:
1. My preferred approach would be to set these parameters in an initialization call. (There already is one, anyhow.)
2. Sometimes it might be useful to have quick and easy ways to set some of these parameters experimentally, but I expect that operationally they would almost always be set up once and left that way forever.  In any case, records for setting parameters could be allowed, but shouldn't be required.
3. I think it unlikely that one will want to set "num_ai_chans" (controls the number of ai channels that are updated by the driver) after initialization, at least until we have an EPICS version that allows dynamic record allocation.  (Would it be a good idea to set this based on the records that are found?  Just an idea.)
Thanks for your input.
   Pam.
Description: iterlogo
Pamela Gurd
External Contractor
CODAC Division
ITER Organization, Building 519/026, DIP, Directorate for CODAC, Heating and Diagnostics
Route de Vinon sur Verdon – 13115 St Paul Lez Durance – France
Phone: +33 4 42 17 64 88
Request for opinions about device driver/support Gurd Pamela EXT
Prev: Request for opinions about device driver/support Gurd Pamela EXT
Next: RE: Problem with caget on 3.14.12.1? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: asyn connection management with asynPortDriver Euan.Troup
