On 6/9/11 11:58 AM, Andrew Johnson wrote:
> Comments/ideas? Just document it and ignore it?
Hi, Andrew.
My vote would be to fix the preprocessor; it shouldn't do that
substitution.
Why does using "vxWorks.h" work when <vxWorks.h> does not?
Because it thinks "vxWorks.h" is a C string constant and so
doesn't touch it?
I'm not the biggest fan of using "vxWorks.h". It's, as you
said, a workaround. When I read that, I think the author wrote
a vxWorks.h header file and wants to include it.
Your suggestion to adjust the sequencer's build rules seems like
an OK workaround if fixing the real problem is considered
undesirable.
I'm not a big fan of deleting the line completely. That just
makes it harder to understand how it works. I can no longer
just look at the source code. I'd have to look at the generated
build command at build time to figure out that vxWorks.h gets
included.
Lewis
- Re: Sequencer Preprocessor Build Rules Andrew Johnson
- Sequencer Preprocessor Build Rules Andrew Johnson
driver support for SIS3302 and SIS3305 Hu, Yong
Re: asyn connection management with asynPortDriver Euan.Troup
<2011>
2025
2026
<2011>
2025
2026
