1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: fft
To: [email protected], [email protected]
Date: Tue, 21 Jun 2011 13:25:08 -0500
Hi Michael,
On 2011-06-21 Michael Davidsaver wrote:
> Has anyone done a routine for the aSub record (or similar) which does an
> fft?
> My input is complex data (two waveforms I and Q) as a function of time
> (512 samples).  Data updates come at ~5Hz.
> I was thinking of using
> http://www.fftw.org/fftw3_doc/Complex-DFTs.html#Complex-DFTs
Not sure if this will be any use to you, given that I don't see anything about
complex input data:
  http://www.aps.anl.gov/epics/modules/soft/waveProc/index.html
The waveProc module pre-dates the inclusion of the aSub record in Base and
includes a copy of the genSub record type, plus the spectrum and waveAnl
records.  They might give you some ideas at least.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
fft Michael Davidsaver
Prev: fft Michael Davidsaver
Next: RE: fft Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
