1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: fft
Date: Wed, 22 Jun 2011 17:42:31 +1000
Hi Michael,
  I have one based on genSub which can do complex/real fwd/reverse fft upto 16384 points.
  I can send you a tarball or zip file if you like.
Regards
Andrew Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Michael Davidsaver
> Sent: Wednesday, 22 June 2011 3:43 AM
> To: [email protected]
> Subject: fft
> Has anyone done a routine for the aSub record (or similar) which does
> an
> fft?
> My input is complex data (two waveforms I and Q) as a function of time
> (512 samples).  Data updates come at ~5Hz.
> I was thinking of using
> http://www.fftw.org/fftw3_doc/Complex-DFTs.html#Complex-DFTs
> Suggestions?
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
fft Michael Davidsaver
Prev: Re: fft Michael Davidsaver
Next: Re: fft Andreas Balzer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
