1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: fft
To: [email protected]
Date: Wed, 22 Jun 2011 10:35:14 +0200
I did a waveform soft support using FFTW. Unfortunately I have problems to re-compile it at the moment. :-(
I will inform you when it is ready to use.
Dirk
Michael Davidsaver wrote:
Has anyone done a routine for the aSub record (or similar) which does an fft?
My input is complex data (two waveforms I and Q) as a function of time (512 samples). Data updates come at ~5Hz.
I was thinking of using
http://www.fftw.org/fftw3_doc/Complex-DFTs.html#Complex-DFTs
Suggestions?
fft Michael Davidsaver
Prev: Re: fft Andreas Balzer
Next: Problem with areaDetector netCDF files >2GB on win32-x86 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
