1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Newport XPS and Motor record
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Mon, 27 Jun 2011 14:51:05 +0000
It could also be that the XPS axis is in the wrong 'state'. I think it needs to be in 'ready state' (states 10 to 13) to receive move commands.
I updated the XPS driver recently. So in the next release of the motor support module the driver should indicate if there is a problem (via the motor record MSTA field). So if the axis is in a state which means you can't move it then you will be notified by the record going into alarm state.
Cheers,
Matthew
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Rivers
> Sent: 27 June 2011 15:17
> To: John Dobbins; EPICS Tech-Talk
> Hi John,
> If you translate that error code, -22, using ErrorStringGet in the XPS
> Web terminal interface you will get:
> 0,Error -22 : Not allowed action
> So there is something illegal about the request you are making.  Is it
> possible that you are exceeding a soft limit, etc.?
> Mark
> [mailto:[email protected]] On Behalf Of John Dobbins
> Sent: Monday, June 27, 2011 8:38 AM
> To: EPICS Tech-Talk
> Subject: Newport XPS and Motor record
> All,
> I am using Motor Record R6-4-4 , EPICS R3.14.9, ASYN 4-9 with a Newport
> XPS controller.
> When I send a new position to an actuator I get a messages in the IOC
> like this:
> epics> 2011/06/24 12:35:35.552 SendAndReceive unexpected response
> =-22,GroupMoveAbsolute (GROUP2.POSITIONER,12.00003072008),EndOfAPI
> otherwise everything seems to be working, i.e. motor responds properly.
> Does someone know what this means? The XPS set-up portion of my st.cmd
> script is below.
> Regards and Thanks,
> John Dobbins
> Cornell University
> The XPS set-up portion of my st.cmd script:
> # cards (total controllers)
> XPSSetup(1)
> # card, IP, PORT, number of axes, active poll period (ms), idle poll
> period (ms)
> XPSConfig(0, "erpxps01", 5001, 3, 10, 500)
> # asyn port, driver name, controller index, max. axes)
> drvAsynMotorConfigure("XPS1", "motorXPS", 0, 3)
> # card,  axis, groupName.positionerName, stepsPerUserUnit
> # PR50CC rotational stage
> XPSConfigAxis(0,0,"GROUP1.POSITIONER",100)
> # CMA-12CCCL linear stage
> XPSConfigAxis(0,1,"GROUP2.POSITIONER",20480)
> XPSConfigAxis(0,2,"GROUP3.POSITIONER",20480)
Re: Newport XPS and Motor record Pete Jemian
Newport XPS and Motor record John Dobbins
RE: Newport XPS and Motor record Mark Rivers
Prev: Re: Sequencer news: latest snapshot J. Lewis Muir
Next: Re: Sequencer news: latest snapshot Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Newport XPS and Motor record Mark Rivers
Next: Re: Newport XPS and Motor record Pete Jemian
