1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Mantis 339 "enum string tbl cache read ASYNC IO postponed fixed" bug still around?
To: [email protected]
Date: Wed, 29 Jun 2011 11:43:36 -0500
Hi Tom,
On 2011-06-24 Tom Cumming wrote:
> I'm getting the following message in our gateway log; I suspect that
> we're reproducing mantis 339, (launchpad 541367). We're running epics
> 3.14.9.
>     filename="../../../../src/cas/generic/casStrmClient.cc" line
>  number=1394 postpone asynchronous IO - enum string tbl cache read ASYNC IO
>  postponed ?
> After I get the above message in the gateway logfile, I'm getting random
> values at random times with camonitor on some enumerated type PV's. If I
> get the same message a second time, it gets worse. Restarting the
> gateway fixes it.
> I'm wondering if mantis 339 is fixed, or simply not a problem with newer
> versions of epics. The bug was filed in '09, and I don't see any
> movement on it.
I can't answer that question myself but I'm guessing there has been no work on
it since 2009 — we have fixed CAS bugs in the more recent releases, but Jeff
Hill is usually pretty good at updating the bug tracker (Launchpad) when he
fixes something.  Given the forest fires around the Los Alamos Lab right now
I'm not expecting that we'll hear from him for a while, unfortunately.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Mantis 339 "enum string tbl cache read ASYNC IO postponed fixed" bug still around? Tom Cumming
Prev: Re: Bug on alh (alarm handler) 1.2.26 alConfig.c file Andrew Johnson
Next: problem with ip330-2-6 (A/D converter board) scanmode functionality to switch modes at runtime Jay Steele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Mantis 339 "enum string tbl cache read ASYNC IO postponed fixed" bug still around? Tom Cumming
Next: Newport XPS and Motor record John Dobbins
