1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event
To: <[email protected]>
Date: Fri, 1 Jul 2011 09:58:14 +0200
Could you also post
- a dump of the epics the record (dbpr "record-name")
- the record type
- whether the record is on the same IOC as the state machine or not
- whether it is always the same PV that has the problem
Cheers
Ben
On Friday, July 01, 2011, Utzel Nadine wrote:
> Thanks for your answer. As commented by Pam, we have no access security
> on the IOCs and as it is a random problem, sometimes everything is just
> working fine! So when it is not the case, I can see something like that
> using SeqChanShow: #15 of 26:
> Channel name: "CTRL-MCOD-TCS:endTestGuard"
>   Unexpanded (assigned) name: "{MC}-TCS:endTestGuard"
>   Variable name: "endTestGuard"
>     address = 20762476 = 0x13ccf6c
>     type = short
>     count = 1
>   Value = 0
>   Monitor flag = 1
>     Monitored
>   Assigned
>   Connected
>   Get not completed or no get issued
>   Put not completed or no put issued
>   Status = 0
>   Severity = 0
>   Message =
>   Time stamp = <undefined>
> Next? (+/- skip count)
> As you can see, the variable is monitored, assigned and connected, but
> the Time stamp is undefined and the variable has not received its first
> monitor event.
> Cheers,
> Nadine
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 30 June 2011 17:14
> To: [email protected]
> Cc: Utzel Nadine
> Hi Nadine,
> On 2011-06-30 Utzel Nadine wrote:
> > Randomly in some of my state programs, I notice that not all the
> > monitored  PVs receive a first monitor event:
> > numMonitoredChans 10 firstMonitorCount 9 assignCount 16
> > firstConnectCount
> >  16 numMonitoredChans 20 firstMonitorCount 19 assignCount 26
> > firstConnectCount 26
> > As a consequence, with the option +c, the state machine stays in its
> > initial state, or with the option -c, it waits for an event flag that
> > is  never sent.
> If you want us to help you're going to have to investigate and post some
> more information about those channels that are not receiving a first
> monitor (use seqChanShow to do that).  I can think of at least one
> reason why this might happen — your sequencer program user & host
> doesn't have Access Security permission on the IOC to read those
> channels for example, although if your IOC is not configured to use
> Access Security then that wouldn't apply.
> - Andrew
> Optimization is the process of taking something that works and replacing
> it with something that almost works, but costs less. -- Roger Needham
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Utzel Nadine
Re: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Andrew Johnson
RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Utzel Nadine
Prev: RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Utzel Nadine
Next: Announce: sequencer 2.1.0 release candidate Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Allison, Stephanie
