1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installation of EPICS
To: [email protected]
Date: Thu, 07 Jul 2011 10:12:35 -0500
Not to discourage reading the documentation thourougly but...
The biggest hold back to starting the make on epics base is defining the environment EPICS_HOST_ARCH.   For your system, this will either be linux-x86 or linux-x86_64.  If you are looking to just take a test drive and run a softIOC on Linux then this is sufficient.  If not, you will need to configure your target environment, see the second link from Marcio below for supported platforms & compilers.
Once you have base built, Section 2 of the App Developer Guide will get you through setting up an IOC.  I would suggest getting the example up and running as a start.
Once this is up and running you will probably need some tools to "see" your IOC.  For this, look at Michael's section on EDM or take a look at CSS (http://sourceforge.net/apps/trac/cs-studio/wiki).
John
On 7/7/2011 9:19 AM, Márcio Paduan Donadio wrote:
On 07.07.2011 14:28, vivek chalotra wrote:
Hello all !
I am new to EPICS and i want to install it under Scientific Linux CERN 5.5.
So please let me know the installation instructions.
    Michael Davidsaver wrote a tutorial, you can access here: https://pubweb.bnl.gov/~mdavidsaver/epics-doc/epics-starting.html
    For EPICS version 3.14.12 (the last one) see this link: http://www.aps.anl.gov/epics/base/R3-14/12-docs/README.html
    Probably you'll want to install synApps also. Choose the version based on the EPICS Release you've chosen. See the documentation and download of tar.gz in this page: http://www.aps.anl.gov/bcda/synApps/index.php
Computer Engineer
SOL - Software de Operação das Linhas de Luz (Beamline Software Operation)
Laboratório Nacional de Luz Síncrotron – CNPEM/ABTLuS
+ 55 (19) 3512-3520
[email protected]
www.lnls.br
John Hammonds
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]<mailto:[email protected]>
(630)252-5317
Re: Installation of EPICS Márcio Paduan Donadio
Prev: RE: AreaDetector CBF file writing plugin emma.shepherd
Next: Re: EDM and record processing Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installation of EPICS Márcio Paduan Donadio
Next: Errors building EPICS with MinGW Morgan Bradford
