1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PPC603 / PPC604 differences?
To: [email protected]
Date: Thu, 7 Jul 2011 11:10:01 -0500
Hi Dirk,
On 2011-07-07 Dirk Zimoch wrote:
> Can anyone tell me the differences between ppc603 and ppc604 from the
> software point of view? Are there instructions that one type supports
> and the other doesn't?
I think the main differences are some of the special-purpose registers (SPRs)
that are accessible at Supervisor level, used for obscure things like
performance monitoring and power or thermal management.  The basic instruction
set is common to all 32-bit PowerPC CPUs, so it's only if you're doing BSP-
level things like turning Caches on/off or programming the MMU that the
differences really matter.  The SPRs are accessed using the mtspr and mfspr
instructions.  There are also a few optional and implementation-specific
instructions that the two Microprocessor Technical Summary documents I found
online mention briefly.
I added two new target architectures to Base 3.14.12.1, vxWorks-ppc32 and
vxWorks-ppc32sf (soft-float) so sites don't have to compile the code more than
is really necessary.  Here at APS we're using them as part of our switch to
vxWorks 6.8, so our engineers can convert IOCs to 3.14.12.1 using the old
targets on vxWorks 5.5.2, but then switch to 6.8 using the same release of
Base with the new targets so we can separate out any issues due to the OS-
version.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: PPC603 / PPC604 differences? Till Straumann
PPC603 / PPC604 differences? Dirk Zimoch
Prev: Re: EDM and record processing Ned Arnold
Next: RE: EDM and record processing Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: PPC603 / PPC604 differences? Dirk Zimoch
Next: Re: PPC603 / PPC604 differences? Till Straumann
