Hi Morgan,
On 2011-07-07 Morgan Bradford wrote:
> I am trying to install EPICS Base on a Windows 7 computer, but keep getting
> the following error. I've tried two different builds, 3.14.9 and
> 3.14.12.1, and have the same problem with both. Any ideas?
> g++ -c -pedantic -O3 -Wall -D__cplusplus -I. -I..
> -I../ ../../src/libCom/bucketLib -I../../../src/libCom/ring
> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
> -I../../../src/libCom/cppStd -I../../../src/libCo m/cxxTemplates
> -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../.
> ./src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr
> -I../.. /../src/libCom/freeList -I../../../src/libCom/gpHash
> -I../../../src/libCom/logCl ient -I../../../src/libCom/macLib
> -I../../../src/libCom/misc -I../../../src/libC om/osi
> -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/l
> ibCom/tsDefs -I../../../include/os/WIN32 -I../../../include
> ../../../src /libCom/bucketLib/bucketLib.c
> ../../../src/libCom/bucketLib/bucketLib.c: In function 'ITEM**
> bucketStringCompa re(ITEM**, const void*)':
> ../../../src/libCom/bucketLib/bucketLib.c:216:21: error: invalid conversion
> from 'const void*' to 'const char*'
> ../../../src/libCom/bucketLib/bucketLib.c: In function 'BUCKETID
> bucketUnsignedH ash(BUCKET*, const void*)':
> ../../../src/libCom/bucketLib/bucketLib.c:238:25: error: invalid conversion
> from 'const void*' to 'const unsigned int*'
> bucketStringHas h(BUCKET*, const void*)':
> ../../../src/libCom/bucketLib/bucketLib.c:288:21: error: invalid conversion
Your build is compiling a C file using the C++ compiler, which is probably
what's causing the failure. Please try applying the patch below (for
3.14.12.1, but you should be able to match it on 3.14.9) which deletes an old
build rule. If this fixes it I'll add it to the Known Problems page.
=== modified file 'configure/RULES_BUILD'
--- configure/RULES_BUILD 2010-10-05 19:27:37 +0000
+++ configure/RULES_BUILD 2011-06-07 14:52:54 +0000
@@ -205,11 +205,6 @@
@$(RM) $@
$(COMPILE.cpp) $(call PATH_FILTER,$<) $(COMPILE_FILTER.cpp)
-%$(OBJ): %.C
- @$(HDEPENDS_CMD)
- @$(RM) $@
- $(COMPILE.cpp) $(call PATH_FILTER,$<) $(COMPILE_FILTER.cpp)
# WIN95/NT resource compiler
%$(RES): %.rc
@$(RM) $@
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Errors building EPICS with MinGW Morgan Bradford
Re: Creating a Simple EPICS Sequencer Program Bradley Pietrzak
<2011>
2025
2026
RE: Errors building EPICS with MinGW Jeff Hill
<2011>
2025
2026
