1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: CSS errors: cannot excute
To: "Kasemir, Kay" <[email protected]>, "Chen, Xihui" <[email protected]>
Date: Thu, 14 Jul 2011 11:46:42 +0800 (CST)
Thank you for your helping!
Followed your advice, I installed the real sun/oracle java 1.6.0_26. Now CSS run correctly .Cheers!
Thank you again.^_^
Xiaoyuan
> -----Origin email-----
> From: "Kasemir, Kay" <[email protected]>
> Sent Time: Thursday, July 14, 2011
> To: "Chen, Xihui" <[email protected]>, "Ma Xiaoyuan" <[email protected]>, tech-talk <[email protected]>
> Cc:
> Subject: RE: CSS errors: cannot excute
> Hi:
> >> It looks like your Java version is 1.4.2, but CSS needs Java 1.6.0 and up to run
> >> it. Please install the latest Java version and try again.
> > I download the CSS_EPICS_2.2.0 version. When I excute "./css" , errors came as follows:
> >    at gnu . gcj . runtime . FirstThread . run() (/usr/lib/libgcj.so.5.0.0)
> You're using the gnu GCJ almost-like-java java compiler.
> You need to install the real sun/oracle java.
> At the same place where you downloaded CSS_EPICS, see "Known Issues":
> " CSS Won't run
> If it doesn't run at all, see Java Versions.
> Linux
> In a terminal, run "java -version". RedHat Linux by default includes the GNU version of Java. This will not work, you have to get the Sun Java 1.6.
> -Kay
RE: CSS errors: cannot excute Kasemir, Kay
CSS errors: cannot excute Ma Xiaoyuan
RE: CSS errors: cannot excute Chen, Xihui
Prev: Re: streamdevice + asyn stuck Eric Norum
Next: JLab Controls Web Pages Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CSS errors: cannot excute Kasemir, Kay
