1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: About CSS/BOY
To: patard <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 21 Jul 2011 14:05:17 -0400
Hi Charles,
>I've tested the version 3.0.0 of CSS/BOY and I guess the bug wasn't fixed because the menu always appears when I restart CSS in "OPI runtime". Or may be my process to do this isn't good.
Sorry, it was my misleading. The compact mode cannot be restored after CSS restarted. To achieve this function, I plan to add two static methods to ScriptUtil: ScriptUtil.compactMode() and ScriptUtil.fullScreen(). You can attach a script to your OPI to force it to compact mode whenever the OPI is started. Again, these methods are available in next release.
>Secondly, I tried, to launch an opi file in other window CSS/BOY (not in a new tab) by a click on Action Button. The only solution I've found is to attach a "Execute _javascript_"  in property Actions.
You can right click the action button and select “Open in new window” or Press “Shift” while clicking to launch an opi in new window.
Xihui
About CSS/BOY patard
Prev: Re: Where is histogram? Andrew Johnson
Next: Static Linking... David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: About CSS/BOY patard
Next: Re: About CSS/BOY patard
