1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: question regarding VxStats-1-7-2h (doesn't seem to measure CPU load properly)
Date: Mon, 25 Jul 2011 23:30:51 -0700
Hi EPICS folks,
     I tried using VxStats-1-7-2h to diagnose a VxWorks problem that it turned out was caused by a State Notation Language (SNL) transition that returned back to the same state without any delays continuously. This seemed to take so much CPU time that the VxWorks Channel Access Server just froze up.
    When I checked the VxStats $(P)Load PV when (1) the Channel Access Server was working just fine and when (2) it was frozen, the value was 11.8 both times. Am I correct in assuming that the $(P)Load PV should have caught this problem and showed something like 100 when the VxWorks Channel Access Server was frozen?
Here’s the $(P)Load PV when everything is working.
dbpr "21:D3:Load",10
ACKS: NO_ALARM      ACKT: YES           ADEL: 0
ALST: 11.4260407440213                  AOFF: 0             ASG:
ASLO: 1             ASP: 0x0            BKPT: 00            DESC: CPU Load
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DPVT: 0x1dff0ff0    DSET: 0x1ec4ce48    DTYP: VX stats      EGU: %
EGUF: 0             EGUL: 0             EOFF: 0             ESLO: 1
EVNT: 0             FLNK:CONSTANT 0     HHSV: MAJOR         HIGH: 50
HIHI: 80            HOPR: 100           HSV: MINOR          HYST: 0
INIT: 0             INP:INST_IO @cpu    LALM: 11.4260407440213
LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW: 0              LSET: 0x1df4b6a0
LSV: NO_ALARM       MDEL: 0
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00                   MLOK: 1e 1f a7 a0
MLST: 11.4260407440213                  NAME: 21:D3:Load    NSEV: NO_ALARM
NSTA: NO_ALARM      ORAW: 0             PACT: 0             PBRK: 0x0
PHAS: 0             PINI: NO            PPN: 0x0            PPNR: 0x0
PREC: 0             PRIO: LOW           PROC: 0             PUTF: 0
RDES: 0x1ed80310    ROFF: 0             RPRO: 0             RSET: 0x1ec52624
RVAL: 0             SCAN: I/O Intr      SDIS:CONSTANT       SEVR: NO_ALARM
SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT
SMOO: 0             SPVT: 0x1defdc00    STAT: NO_ALARM      SVAL: 0
TIME: 1990-01-01 18:34:43.880000000     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 0              VAL: 11.4260407440213
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
RE: question regarding VxStats-1-7-2h (doesn't seem to measure CPU loadproperly) Dalesio, Leo
Prev: question regarding VxStats-1-7-2h (doesn't seem to measure CPU load properly) Jay Steele
Next: Re: question regarding VxStats-1-7-2h (doesn't seem to measure CPU load properly) Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: question regarding VxStats-1-7-2h (doesn't seem to measure CPU load properly) Ralph Lange
Next: RE: question regarding VxStats-1-7-2h (doesn't seem to measure CPU loadproperly) Dalesio, Leo
