1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: question about state notation language logic for when() with delay
Date: Wed, 10 Aug 2011 09:01:40 -0700
Hi EPICS folks,
  For the state notation language, the when statement is mostly straightforward in that the code following the when statement occurs when the logical _expression_ inside the when statement is true. However, I'm a little confused by the delay function in a when statement because something needs to start and monitor the timer for the delay. I need to understand this delay logic better for a EPICS robot control application I'm working on. When does the timer start and how is it monitored for the delay? For example, if I use the following when statement for a state transition,
when(A==1 && delay(1.0) && B==1),
  does the timer for the delay only start and continue after the A==1 logical condition is met and, after the delay is done, then it checks the B==1 logical condition? Thus, does the order of logical conditions in the when statement make a difference so that when(delay(1.0) && A==1 && B==1) behaves differently? Here is one possible interpretation of when(A==1 && delay(1.0) && B==1):
time     A     B    transition
0         0      0    none
1         0      0    none
2         1      0    none
2.5      1      1    none
3         1      0    none
4         1      1    yes
  Or, does the timer for the delay only start and continue after both the A==1 and B==1 conditions are satisfied? In which case, we get the following result for when(A==1 && delay(1.0) && B==1):
time    A        B    transition
0        0        0       none
1        0        0        none
2        1        0       none
2.5     1        1       none
3        1        0       none
4        1         1      none
5        1         1      yes
Or does the timer for the delay start as soon as the state containing the when statement becomes active and just continue? In this case, the results would be as follows for when(A==1 && delay(1.0) && B==1).
time    A     B    transition
0        0      0      none
1        0      0      none
2        1      0      none
2.5     1      1      yes
  I will test these different situations out, but I wanted to understand the underlying logic intent so that my SNL implementation will not break with future software versions.
Cheers,
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Re: question about state notation language logic for when() with delay Chestnut, Ronald P.
Prev: areaDetector R1-7 released Mark Rivers
Next: Re: question about state notation language logic for when() with delay Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
