> error C2440:
> 'initializing' : cannot convert from 'const void *' to 'const char *'
> Conversion from 'void*' to pointer to non-'void' requires an
> explicit cast
Interesting. My version of that old code has the same "const void *" to
"const char *" assign w/o a cast, but visual studio pro 2010 doesn?t
generate even a warning (and certainly not an error).
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Williams Jr., Ernest L.
> Sent: Thursday, August 18, 2011 8:35 AM
> To: Jüri Tagger
> Cc: [email protected]
> Subject: RE: Building EPICS (3-14-12-1) on Windows 7
> Hi Juri,
> When I try with the unpatched version of EPICS BASE base-3-14-12-1 I get:
> rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -
> I../../../
> src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -
> I../../../src/li
> bCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -
> I../../../sr
> c/libCom/cppStd -I../../../src/libCom/cxxTemplates -
> I../../../src/libCom/dbmf -I
> ../../../src/libCom/ellLib -I../../../src/libCom/env -
> I../../../src/libCom/error
> -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -
> I../../../src/libCo
> m/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -
> I../../../
> src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -
> I../../.
> ./src/libCom/taskwd -I../../../src/libCom/timer -
> I../../../src/libCom/tsDefs -I.
> ./../../include/os/WIN32 -I../../../include -fo Com.res ../Com.rc
> Microsoft (R) Windows (R) Resource Compiler Version 6.1.7600.16385
> Copyright (C) Microsoft Corporation. All rights reserved.
> cl /nologo /EHsc /GR -c /nologo /D__STDC__=0
> /D_CRT_SECURE_NO_DEPR
> ECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MD /TP
> -I. -
> I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -
> I..\\..\\..\\src\\l
> ibCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -
> I..\\..\\..\\
> src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -
> I..\\..\\..\\src\\libCom\\cvt
> Fast -I..\\..\\..\\src\\libCom\\cppStd -
> I..\\..\\..\\src\\libCom\\cxxTemplates -
> I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -
> I..\\..\\..\\s
> rc\\libCom\\env -I..\\..\\..\\src\\libCom\\error -
> I..\\..\\..\\src\\libCom\\fdmg
> r -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -
> I..\\..
> \\..\\src\\libCom\\iocsh<file://..//src//libCom//iocsh> -
> I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\
> \libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -
> I..\\..\\..\\src\\libCom\\osi -
> I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -
> I..\\..\\..\\
> src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include
> ..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c
> bucketLib.c
> ..\..\..\src\libCom\bucketLib\bucketLib.c(125) : error C2440:
> 'initializing' : c
> explicit ca
> st
> ..\..\..\src\libCom\bucketLib\bucketLib.c(147) : error C2440:
> 'initializing' : c
> annot convert from 'const void *' to 'const unsigned int *'
> explicit ca
> st
> ..\..\..\src\libCom\bucketLib\bucketLib.c(197) : error C2440:
> 'initializing' : c
> explicit ca
> st
> make[3]: *** [bucketLib.obj] Error 2
> make[3]: Leaving directory `C:/epics/base/base-R3-14-12-
> 1/src/libCom/O.win32-x86
> make[2]: *** [install.win32-x86] Error 2
> make[2]: Leaving directory `C:/epics/base/base-R3-14-12-1/src/libCom'
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory `C:/epics/base/base-R3-14-12-1/src'
> make: *** [src.install] Error 2
> C:\epics\base\base-R3-14-12-1>
> Regards,
> Ernest
> From: Jüri Tagger [[email protected]]
> Sent: Thursday, August 18, 2011 12:41 AM
> To: Williams Jr., Ernest L.
> Good morning,
> I built 3.14.12.1 on Windows 7 with Visual Studio 2010 straightforward.
> Patch, http://www.aps.anl.gov/epics/tech-talk/2010/msg00595.php , is not
> necessary. I did it with make-3.82-3-mingw32 and ActivePerl-5.12.2.1203-
> MSWin32-x86
> It should work! (Provided paths and environment variables are right.) The
> only thing I had to do was to run the bat file:
> "C:\Program Files\Microsoft Visual Studio 10.0\Common7\Tools\vsvars32.bat"
> (use quotation marks for entering this command line) On success it prints
> out:
> Setting environment for using Microsoft Visual Studio 2010 x86 tools.
> set EPICS_HOST_ARCH=win32-x86
> C:\MinGW\bin\mingw32-make (while standing in the EPICS base directory).
> Cheers,
> J. Tagger
> MAX - lab
- Building EPICS (3-14-12-1) on Windows 7 Williams Jr., Ernest L.
- RE: Building EPICS (3-14-12-1) on Windows 7 Williams Jr., Ernest L.
RE: Building EPICS (3-14-12-1) on Windows 7 Jeff Hill
Re: Building EPICS (3-14-12-1) on Windows 7 Ernest L. Williams Jr.
<2011>
2025
2026
<2011>
2025
2026
