1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues
To: [email protected]
Date: Thu, 18 Aug 2011 11:28:35 -0500
Hello All,
I have set up EPICS on a Scientific Linux 5.5 computer with the 2.6.18-238.9.1.el5 kernel. I am using CSS to try and read the PV back in BOY. When I type the PV in the field then run the OPI it will display a disconnected message and no values are read. If I do the call from the terminal I can read the value back with no issue. I have also tried this on a Windows XP machine with the same results. Do you know what steps I could take for further troubleshooting to find out why this is showing disconnected? Or what other information would be helpful is troubleshooting the problem. Thanks for the help.
Cheers,
Adam Gluck | Applications Engineer | National Instruments
Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues Kasemir, Kay
Prev: Re: CSS EPICS PV connectivity issue Kasemir, Kay
Next: Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
