1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues
To: Adam Gluck <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 18 Aug 2011 13:16:27 -0400
Hi again:
Check the menu CSS/Preferences/CSS Core/EPICS for the auto addr. list and
addr list settings.
How do the settings compare to the EPICS_CA_*_ADDR_LIST environment
variables used by the command-line caget?
What if you de-select auto_addr_list and set the address list to the IP of
one of your IOCs? Do you then see the PVs on there?
What if you de-select auto_addr_list and set the address list to the IP of a
broadcast address that includes one of your IOCs?
Kay
On 8/18/11 13:14 , "Kay Kasemir" <[email protected]> wrote:
> Hi:
> On 8/18/11 12:28 , "Adam Gluck" <[email protected]> wrote:
>> Hello All,
>> I have set up EPICS on a Scientific Linux 5.5 computer with the
>> 2.6.18-238.9.1.el5 kernel. I am using CSS to try and read the PV back in
>> BOY. When I type the PV in the field then run the OPI it will display a
>> disconnected message and no values are read. If I do the call from the
>> terminal I can read the value back with no issue. I have also tried this
>> on a Windows XP machine with the same results. Do you know what steps I
>> could take for further troubleshooting to find out why this is showing
>> disconnected? Or what other information would be helpful is
>> troubleshooting the problem. Thanks for the help.
>> Cheers,
>> Adam Gluck | Applications Engineer | National Instruments
Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues Adam Gluck
Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues Kasemir, Kay
Prev: Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues Kasemir, Kay
Next: Scalcout data corruption on darwin-x86 with x86_64 arch class J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues Adam Gluck
