On 8/24/11 3:29 PM, Chen Xue wrote:
> Hi, there,
> I have a host machine and MVME 5100 card in a crate. Everything
> worked fine before I moved both of them to a new place. After I
> shut off the machine and crate and moved to another place, I
> can't reboot the IOC. The error message is 'Error in boot
> line'... 'Can't load boot file'. Could someone help me to fix
> the problem?
Hi, Chen.
Can you post the actual error message?
Are you booting from NFS or FTP?
Is the network cable plugged in?
Is the MVME 5100 on the same network as it was before? If not,
you may need to change the settings for the network adapter at
the firmware prompt.
Can you check the access log of the NFS or FTP server to ensure
the MVME 5100 is successfully connecting to obtain the boot image?
Lewis
- Reboot VME problem Chen Xue
Newbe question - PV limits Paul Nord
<2011>
2025
2026
<2011>
2025
2026
