1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Configuring an IOC to -not- build for host arch
Date: Wed, 31 Aug 2011 17:48:22 -0400
This problem seems to have been discussed about a year ago,
(http://www.aps.anl.gov/epics/tech-talk/2010/msg01432.php) but I still can't solve it.
I have a linux-x86_64 host and a linux-x86 target. I want to build IOC's and libraries for the
target only, not for the host.
As mentioned below, both my host and target have the same OS class, so I can't use the
PROD_IOC_<osclass> to differentiate them.
I tried the BUILD_FOR_HOST_ARCH set to the empty string as suggested below. I set that
variable in the IOC's '<TOP>/configure/CONFIG_SITE'. But that still built for the host as
well as the target.
Any suggestions as to what I'm doing wrong, or what I might try next are greatly appreciated.
Thanks
________________________________________________________
Subject:Re: Configuring an IOC to -not- build for host arch
To:[email protected]
Date:Sun, 19 Sep 2010 21:27:28 -0700
 Hi Angus,
You can also use the technique Mark mentions for your IOC build:
PROD_IOC_RTEMS    = <appname>
That method, however, just restricts that library or product to a single OS class.
If you have more than one supported architecture for that OS, both will build.
For example, we build with host arch linux-x86_64, but cross compile for linux-x86
as well as RTEMS.    Using PROD_IOC_Linux still builds both linux targets, so
to build just the 32 bit IOC, I set the following in configure/CONFIG_SITE:
CROSS_COMPILER_TARGET_ARCHS = linux-x86
BUILD_FOR_HOST_ARCH=
Note that you can't just set BUILD_FOR_HOST_ARCH=0, it must be an empty string.
- Bruce
Re: Configuring an IOC to -not- build for host arch Andrew Johnson
Prev: EPICS Collaboration Meeting Fall 2011 Dirk Zimoch
Next: Re: Advantech USB-4700 Series Pete R. Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Configuring an IOC to -not- build for host arch Andrew Johnson
