1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Time-Stamp for Asynchronous records
To: [email protected]
Date: Thu, 8 Sep 2011 15:42:38 -0500
Hi John,
On 2011-09-08 Benjamin Franksen wrote:
> Am Donnerstag, 8. September 2011, um 22:10:10 schrieb John Dobbins:
> > I am wondering about the time-stamp for a record with asynchronous
> > device support. Does the time-stamp indicate the time processing started
> > or completed. (I am guessing the later but wanted to be sure.)
> The precise answer is: it depends on the record type (look into the source
> code of record support to find out). However, all record types that I know
>  of set the timestamp after calling device support for the second time, so
>  for all practical purposes the answer is: yes, the latter.
It also depends on the TSEL and TSE fields, which can cause the timestamp to
be fetched from another record (if you point TSEL to another record's .TIME
field), an event system (set TSE or point TSEL to a numeric field giving the
event number) or assume that device support has set the timestamp itself (set
TSE to -2).
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Time-Stamp for Asynchronous records John Dobbins
Re: Time-Stamp for Asynchronous records Benjamin Franksen
Prev: Re: Time-Stamp for Asynchronous records Benjamin Franksen
Next: Need std 2.9 to build mca Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
