1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to write a python-based backpup tool?
To: Matt Newville <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 16 Sep 2011 15:38:31 -0700
With same request files ( ~11K Pvs), I have
sddscasr 2 sec
burtrb   2 sec
python  10 sec
(with gigabit network)
I am wondering what is the reason for the difference.
As you can see below, just the connection to PV is comparatively 'slow'
debug output:
[Fri Sep 16 16:11:15 2011] import epics start
[Fri Sep 16 16:11:15 2011] import epics end
[Fri Sep 16 16:11:15 2011] request read
[Fri Sep 16 16:11:21 2011] connected to pv
[Fri Sep 16 16:11:23 2011] fetched PV values
[Fri Sep 16 16:11:23 2011] write on disk
[Fri Sep 16 16:11:23 2011] write completed
with
#!/usr/bin/env python
WRITE_ON_DISK = True
USE_SQLITE = False
import time
print "[%s] import epics start" % time.asctime( time.localtime(time.time()) )
import epics
print "[%s] import epics end" % time.asctime( time.localtime(time.time()) )
pvNames = []
pvs = []
vals = []
with open("burt.req") as fp:
    for line in iter(fp.readline, ''):
        pvNames.append(line[:-1])
print "[%s] request read" % time.asctime( time.localtime(time.time()) )
for pvName in pvNames:
    pvs.append(epics.PV(pvName))
print "[%s] connected to pv" % time.asctime( time.localtime(time.time()) )
for pv in pvs:
    vals.append(pv.get())
print "[%s] fetched PV values" % time.asctime( time.localtime(time.time()) )
if not WRITE_ON_DISK : exit()
print "[%s] write on disk" % time.asctime( time.localtime(time.time()) )
if USE_SQLITE :
    from pysqlite2 import dbapi2 as sqlite
    connection = sqlite.connect('test.db')
    cursor = connection.cursor()
    cursor.execute('CREATE TABLE backup (id INTEGER PRIMARY KEY, pvname VARCHAR(50), value VARCHAR(50))')
    for index, pvName in enumerate(pvNames):
        sqlquery = "INSERT INTO backup VALUES (null, '%s','%s')" % (pvName, vals[index] )
        #cursor.execute('INSERT INTO names VALUES (null, "%s" % pvName, "%s" % vals[index])')
        cursor.execute(sqlquery)
    connection.commit()
    cursor.close()
    connection.close()
else:
    with open("test.txt",'w') as fp:
        for index, pvName in enumerate(pvNames) :
            print >>fp , "%s %s" % ( pvName, vals[index] )
print "[%s] write completed" % time.asctime( time.localtime(time.time()) )
On 16:30 Fri 16 Sep     , Matt Newville wrote:
> Hi Emmanuel,
> On Fri, Sep 16, 2011 at 3:09 PM,  <[email protected]> wrote:
> >> pvlist = []
> >>     pvlist.append( epics.PV(pvName) )
> >> for pvs in pvlist:
> >>     val = pv.get()
> >>     <store value>
> >> With this sort of approach, I typically see on the order of 10ms per
> >> PV connection on startup.   That is, if I create and connect to 5K
> >> PVs, it takes ~50 seconds (meaning 40 to 80 seconds) to get initial
> >> values.  I believe that is mostly the CA library, not the python part,
> >> and I believe it would scale, suggesting that any save/restore process
> >> that runs once and then quit would take 10 minutes for 50K PVs.
> > Are you saying that 10 min for 50K PVs is also what is observed with C utilities?
> > 10 min for 50K is rather long ...
> I'd be happy to be shown wrong, and I'm certainly not the right person
> here to answer for sure,  but I think this might be the case.
> > If that is the case, then one whould be careful to backup only PV which are of interest
> > and not the 'entire' machine.
> > How is this being managed at large installation?
> I think they break up the set of variables across
> processes/machines/NICs and/or have a long-running process that
> repeatedly saves variables instead of
>     start process; connect to 50K PVs; write values; end process.
> > I understand your points, but somehow I am having a hard time believing this.
> > Did anyone benchmark their backup platform?
> > (I remember seeing a few powerpoints on this issue a while back...)
> For what it's worth, and also gladly proven wrong, etc:  I recall that
> with non-preemptive-callback context, creating and connecting PVs took
> exactly 30ms, to very high precision and reproducibility.  I never
> fully understood that....   From that view, the 10 ms average with the
> preemptive-context is an improvement.
> It's probably easy to tell whether it is closer to 1, 10, or 30 ms
> even with a few hundred PVs.  But even at 1ms / PV connection, you
> would probably want to not start a new connection per PV for saving
> 50K PVs.
> > PS:
> > Is there a difference between a connection to 50K Pvs versus, 50K connections to the same PVs?
> Yes, these are definitely different.
> --Matt
Emmanuel
Re: How to write a python-based backpup tool? Matt Newville
How to write a python-based backpup tool? emmanuel_mayssat
Re: How to write a python-based backpup tool? emmanuel_mayssat
Prev: Re: How to write a python-based backpup tool? Matt Newville
Next: Re: aSubRecord VAL field Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: How to write a python-based backpup tool? Matt Newville
