On 9/22/11 10:53 AM, Bradley Pietrzak wrote:
> Hello,
> The state notation language program shown below runs successfully.
> "magnet1" and "magnet2" are nothing more than simple analog inputs.
> Clearly, state sets one and two are identical, except for the process
> variables on which they operate. Ultimately, I'd like to combine the two
> state sets into a single state set which can operate on either pv1 or pv2,
> depending on which of the two variables I "pass" into it. Does the state
> notation compiler allow for such functionality? Any help would be greatly
> appreciated.
Hi, Bradley.
If you don't need the two state sets to interact with one
another, you could just make the SNL program reentrant ('+r' SNL
compiler option) and use an SNL macro and start two instances of
the SNL program. For example:
program sncExample
option +r;
float pv1;
assign pv1 to "{MAGNET}";
ss ss1 {
state one {
pv1 = 1;
pvPut(pv1);
} state two
state two {
pv1 = 2;
pvPut(pv1);
} state one
Then start two instances, one with MAGNET=magnet1 and the other
with MAGNET=magnet2.
If you need to do it in one SNL program, you could do something
like: set a PV variable indicating which PV you want to operate
on, and then just use a conditional statement in the next state
to do the pvPut on the correct PV.
Or you could dynamically assign the PV at run-time. That is, in
the first state, assign the PV to "magnet1" or "magnet2" using
the SNL pvAssign function. Transition to another state to wait
for it to connect using pvConnected (or perhaps pvAssignCount()
== pvConnectCount()). Then transition to a third state which
does the pvPut.
A fourth possibility would be to obtain the variable index via
pvIndex for each PV you want to write to. Then in the first
state, set a variable indicating the target index (i.e. which PV
you want to operate on), and in the second state invoke the
seq_pvPut C function with the target index.
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
- Re: Combing Two State Sets into One Bradley Pietrzak
- Combing Two State Sets into One Bradley Pietrzak
Re: Combing Two State Sets into One Ned Arnold
<2011>
2025
2026
<2011>
2025
2026
