1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asub record problems to update waveforms of string-type
To: Perrier Pierre <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 23 Sep 2011 14:51:43 +0000
Pierre,
This may only be tangential to your problem, but I have found that when my aSub records update an 'analog out' variable, the value immediately updates everywhere.
OTOH, when updating strings or waveform strings, they only "sort of" update.
A caget will provide the updated string value, but EDM will show the old value.  This is even true when the EDM window is killed and restarted -- which I don't understand at all.
Adding FLNK, "$(P):CRExeSeq.PROC" to your aSub, though not pretty, may fix the immediate problem.
Cheers -Mathias
RE: Asub record problems to update waveforms of string-type Allison, Stephanie
Asub record problems to update waveforms of string-type Perrier Pierre
Prev: Asub record problems to update waveforms of string-type Perrier Pierre
Next: RE: Asub record problems to update waveforms of string-type Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
