1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [S7plc EPICS driver] REAL type record jumps to zero
To: Di Maio Franck <[email protected]>
Date: Tue, 27 Sep 2011 17:32:24 -0400
Di Maio Franck wrote:
But I also wonder if others with similar requirements (predictable traffic with PLC) are using a dedicated network interface to separate the PLC traffic from CA.
Hello Franck--
How predictable do you require, and how fast are you expecting for PLC to EPICS communications? For SNS, we are not relying on tight timing requirements between IOC and PLC (typically ~1 second is adequate) and we can tolerate a long timeout (several seconds). Anything with lower tolerance is handled within the PLC (or within the IOC). With this expectation, we do not see anything like your flicker, and when we have seen problems, it has generally been traced to a buggy firmware version on the PLC or bad hardware (e.g. damaged network cable). The SNS network is relatively flat and has lots of traffic. A dedicated network may be beneficial, but I think in our case, the inefficient network protocol to the AB PLCs is more of a limitation then the network capacity. I don't have experience with the S7 PLCs for comparison.
Steven Hartman
[email protected]
RE: [S7plc EPICS driver] REAL type record jumps to zero Di Maio Franck
[S7plc EPICS driver] REAL type record jumps to zero Pavel Masloff
Prev: RE: [S7plc EPICS driver] REAL type record jumps to zero Di Maio Franck
Next: Transform Record no_inlink test Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: [S7plc EPICS driver] REAL type record jumps to zero Di Maio Franck
