1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Simple ADC - Ethernet device?
To: Paul Nord <[email protected]>
Cc: [email protected]
Date: Thu, 29 Sep 2011 14:27:41 -0700
ADC to RS485
http://www.techmatron.com/produit.php?idProduit=677 $300
with
RS485 to Ethernet
http://tibbo.com/products/controllers/ds100.html $100
+ stream based drive
you can probably find even cheaper ...
Enjoy!
Emmanuel
On 13:08 Tue 27 Sep     , Paul Nord wrote:
> David,
> That one looks like a simple elegant one-piece solution.
> Help me understand, "Relatively easy to implement."  Does that must mean that I'd need the Modbus driver and I'd set an IP address and name a couple of things?  Or will I need to understand a whole lot more about the inner workings of the device?
> Be careful how you answer.  My next follow-up question is:  I'll be at BNL next week.  Can I stop by your office to talk about this for a few minutes?  :)
> Paul
> On Sep 27, 2011, at 11:57 AM, David Dudley wrote:
> > Another option is something like a ADAM 6017 from Advantech.
> > They're analog inputs with modbus interface directly on Ethernet.
> > Somewhere around $250 if memory serves....
> > David
Emmanuel
Re: Simple ADC - Ethernet device? David Dudley
Re: Simple ADC - Ethernet device? Paul Nord
Prev: Re: [S7plc EPICS driver] REAL type record jumps to zero Martin L. Smith
Next: Re: Transform Record no_inlink test Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Simple ADC - Ethernet device? Paul Nord
Next: Re: Simple ADC - Ethernet device? Dave Reid
