1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS collaboration meeting
To: EPICS <[email protected]>
Date: Fri, 30 Sep 2011 10:16:29 +0200
Dear colleagues,
The EPICS meeting schedule is quite complete now. Please have a look at http://indico.psi.ch/event/EPICS and tell me if you have reason to change the time slot of your presentation.
Arrival:
Trains go from Airports Zürich and Basel to Brugg regularly. To find your best connection have a look at http://www.sbb.ch/en.
Train fares are 19.40 CHF from Basel to Brugg via Olten and 18.60 CHF from Zürich to Brugg (both 2nd class).
From Brugg railway station, buses to PSI and Böttstein leave regularly at minutes 05 and 35. (Remember, this is Switzerland: The buses will leave on time!). In the morning, additional direct busses to PSI leave at 04 and 34. Travel time is 14 minutes for the regular bus and 11 minutes for the direct bus.
The buses to PSI leave from the front most bus bay in front of the railway station (north exit to Brugg).
You can get but tickets from the bus driver or in the train station. The latter is recommended for six-way-tickets (“Mehrfahrtenkarte”) which cost 20 CHF. The single fare is 4 CHF.
As this is the second-most international bus route in Switzerland, bus drivers and ticket vendors normally understand at least a bit of English.
If you plan to travel a lot in Switzerland, a travel pass may be useful: http://www.swisstravelsystem.ch/en
At PSI:
On Monday and Wednesday, the reception desk is open from 8:30 to 9:00. On Monday in the "Timeout" building, on Wednesday in the Auditorium building. Here is a site map: http://epics.web.psi.ch/PSI%20Plan%20Epics.pdf
Whether forecast:
Fog and 12°C in the morning, in the afternoon sunny and 23°C. No rain.
http://www.meteoschweiz.admin.ch/web/en/weather.html
See you at PSI,
Dirk
Prev: Re: Transform Record no_inlink test Bruce Hill
Next: BOY widgets and protocols other than Channel Access Elliott Wolin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Regarding Labjack and Xcode Kamleshkumar Suthar (suthar)
