Hi Linda,
According to the manual it should be quite straight forward to get it
working:
Terminator = CR LF;
# pass gauge number 1 or 2 as parameter
# connect to ai record, use pressure(1) or pressure(2) in INP
pressure { out "DS IG\$1"; in "%f"; }
# connect to bo record, use switch(1) or switch(2) in OUT
switch {out "IG\$1"; in "OK"; }
# connect to bi record
degas_status { out "DGS"; in "%b"; }
# connect to bo records
degas { out "DG %{OFF|ON}"; in "OK";
@init {degas_status}
Similar for all other commands. There are not that many. You don't need
to take care of the error strings because no error should happen if the
protocols are correct.
I would scan the input record with 1 second.
Cheers,
Dirk
[email protected] wrote:
Is there EPICS support available for the Granville Phillips Series 307
Vacuum Gauge Controller?
Something based on StreamDevice would be ideal but information about any
existing support would be appreciated.
Linda Pratt
Software Systems Engineer
Controls Department
[email protected]
+44 (0)1235 778058
www.diamond.ac.uk
Diamond Light Source Ltd
Diamond House
Harwell Science and Innovation Campus
DIDCOT
Oxfordshire
OX11 0DE
UK
This e-mail and any attachments may contain confidential, copyright and
or privileged material, and are for the use of the intended addressee
only. If you are not the intended addressee or an authorised recipient
of the addressee please notify us of receipt by returning the e-mail and
do not use, copy, retain, distribute or disclose the information in or
attached to the e-mail.
Any opinions expressed within this e-mail are those of the individual
and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Ltd. cannot guarantee that this e-mail or any
attachments are free from viruses and we cannot accept liability for any
damage which you may sustain as a result of software viruses which may
be transmitted in or with the message.
Diamond Light Source Limited (company no. 4375679). Registered in
England and Wales with its registered office at Diamond House, Harwell
Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
- EPICS support for Granville Phillips Series 307 Vacuum Gauge Controller Linda.Pratt
Re: EPICS support for Granville Phillips Series 307 Vacuum Gauge Controller Mohan Ramanathan
Re: EPICS support for Granville Phillips Series 307 Vacuum Gauge Controller Tim Mooney
<2011>
2025
2026
RE: EPICS support for Granville Phillips Series 307 Vacuum Gauge Controller Linda.Pratt
<2011>
2025
2026
