Hi Lana,
On 2011-10-17 Abadie Lana wrote:
> I had a quick look at the epics base code but i could not find where the
> link type was set. What I mean is the following:
> In the dbd file, there are some record types which have some fields of type
> INLINK/OUTLINK/FWDLINK. Depending on the cases, it can point to a constant
> (like DOL field for instance) or to a timestamp (TSE) or to a real PV.
> When I looked at the code, there is a notion of link type associated with
> this type of fields and a link type can be either
> CA_LINK/CONSTANT/DB_LINK/PV_LINK(=DB+CA_LINK). However I didn't find where
> and how the links were set at IOC start up. I'm really interesting in
> knowing how the IOC knows if the field points to a real PV... Thanks a lot
> for your help
This is a bit complicated and spread over several source files; I usually have
to go back to the source code to understand it properly every time.
When the storage for a record is allocated, all IN/OUT/FWDLINK fields are
initialized with plink->type = CONSTANT (by dbAllocRecord() in dbStaticRun.c).
Determining whether an INLINK/OUTLINK/FWDLINK field is a CONSTANT or a PV_LINK
takes place when dbPutString() inside src/dbStatic/dbStaticLib.c parses the
string value being assigned to the field. If the field name is INP or OUT it
also has to check the DTYP field since device support determines what link
type it expects to see. A CONSTANT value is found by parsing the string using
both epicsStrtod() and strtol(); if either of those routines accepts the whole
string then it's a CONSTANT, otherwise it becomes a PV_LINK and we parse the
string for the link options appropriate for the link direction.
The code that resolves a PV_LINK type into either a DB_LINK vs CA_LINK exists
in two places; at iocInit time the link resolution occurs in the routine
doResolveLinks() in src/misc/iocInit.c but if you change the link field at
runtime it is then determined in dbPutFieldLink() inside src/db/dbAccess.c.
In both cases the code checks for CA/CP/CPP options and does a dbNameToAddr()
to determine if the link target matches a record and field name found in this
IOC; if found the result is a DB_LINK. If there were CA/CP/CPP options or the
name lookup failed this is a Channel Access link so it calls dbCaAddLink() (a
macro from dbCa.h which expands to dbCaAddLinkCallback() in src/db/dbCa.c with
some default arguments for the callback parameters).
Note that this code has been modified in some branches that will appear in
future (3.15) releases, so talk to me first if you have some requirement that
might involve changing it.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- RE: How the EPICS IOC determines the link type {CA_LINK/DB_LINK/CONSTANT} Abadie Lana
- EPICS Workshop Fall 2011 Dirk Zimoch
- How the EPICS IOC determines the link type {CA_LINK/DB_LINK/CONSTANT} Abadie Lana
Re: Fwd: FW: EPICS driver for acqiris cPCI digitizer is available on epics.sf.net Silver
<2011>
2025
2026
<2011>
2025
2026
