Folks,
asyn R4-18 is now available. Links to the new documentation, release notes and tar file can be found here:
http://www.aps.anl.gov/epics/modules/soft/asyn/
asyn is now also available via the APS Subversion repository here:
https://svn.aps.anl.gov/epics/asyn/
This is from the release notes:
asynPortDriver
Cleaned up logic for callbacks on asynUInt32Digital interface. It was not doing callbacks if the value had not changed but an interrupt had occured for bits in the mask. This would happen when interrupts were only enabled on the falling or rising edges but not both. Added an additional form of setUIntDigitalParam that takes an interruptMask argument. In the previous releases drivers were calling setUInt32Interrupt for callbacks which is not correct. That function should only be called by device support to tell the driver which interrupts to recognize. These problems made the quadEM not work correctly with the ipUnidig.
drvAsynSerialPort
Bug fix on WIN32. It was waiting forever when timeout=0 when it should return whatever characters are available without waiting at all.
Miscellaneous
Changes to avoid compiler warnings on 64-bit Darwin.
Changes to avoid compiler warnings and errors on older Solaris compiler.
Changed non-standard __VAR_ARGS__ to __VA_ARGS__ in asynPrint macro.
Added titles to EDM screens.
Added CSS BOY screens.
Fixed build problem. It was rebuilding the VXI11 code with rpcgen each time make was run, even if nothing had changed.
- Re: asyn R4-18 available Noboru Yamamoto
Re: reading large data arrays over slow networks Peter Jemian
Re: epicsQt plugin build errors 张玉亮
<2011>
2025
2026
<2011>
2025
2026
