1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IOC make error
To: "Cid, Florencio A" <[email protected]>, "Ron Sluiter" <[email protected]>
Cc: [email protected]
Date: Tue, 8 Nov 2011 11:32:34 -0600
http://cars.uchicago.edu/software/pub/make.gz
gunzip it, and rename it from make to make.exe.
Sent: Tuesday, November 08, 2011 11:28 AM
To: Mark Rivers; Ron Sluiter
Mark,
I tend to agree with you regarding figuring out why the latest version of Cygwin make is not working…..
In the meantime, I was wondering if you could please have a copy of your make.gz.   Thought that I would give it a try.
Flo
Sent: Tuesday, November 08, 2011 9:41 AM
To: Cid, Florencio A; Ron Sluiter
Interestingly I see the following:
$ uname -r
1.7.7(0.230/5/3)
$ ls -al /bin/make*
-rwx------+ 1 epics  None     495190 2008-05-23 17:48 /bin/make.exe
-rwxr-x---+ 1 epics  Users    151552 2008-02-09 13:50 /bin/make.exe.old
-rw-r--r--  1 rivers mkpasswd 179495 2009-01-12 14:03 /bin/make.gz
So my version of Cygwin is slightly older than yours, 1.7.7 vs 1.7.9.  I have the same version of make as you which I am NOT using, (it is renamed to make.exe.old) and I am using another version that is about 3 times larger.  I honestly don’t remember where I got the version that I am using.  But the .gz file expands into the version of make.exe that I am using.  I can make that available if you want, but I think we need to figure out why the latest version of Cygwin make is not working?
Sent: Tuesday, November 08, 2011 10:26 AM
Mark,
Cgwin version is as follows:
$ uname -r
1.7.9(0.237/5/3)
Info for /bin/make is as follows:
$ ls -al make
-rwxr-xr-x 1 ui495a root 151552 Feb  9  2008 make
Flo
Sent: Tuesday, November 08, 2011 9:18 AM
Those are the same settings I am using.
What version of Cygwin are you using?  What is the size and date of your /bin/make.exe?
Sent: Tuesday, November 08, 2011 10:04 AM
Mark,
I’ve set the following in the file, CONFIG_SITE,
SHARED_LIBRARIES = NO
STATIC_BUILD = YES
Flo
Sent: Tuesday, November 08, 2011 8:30 AM
To: Ron Sluiter; Cid, Florencio A
I don’t think that tech-talk message of mine applies any more.  That was an attempt to use the Cygwin version of make to build for win32-x86.  That is not supported, and one should use the GnuWin version of make to build for win32-x86.
As far as I know the current Cygwin version of make should work OK to build for the cygwin-x86 architecture, and there is no need to roll back to an earlier version.
Are you building statically or dynamically?
From: [email protected] [mailto:[email protected]] On Behalf Of Ron Sluiter
Sent: Tuesday, November 08, 2011 9:27 AM
Cc: '[email protected]'
Subject: Re: IOC make error
This tech-talk entry may fix your problem.
On 11/7/2011 4:42 PM, Cid, Florencio A wrote:
Hello all,
I’ve just installed EPICS base (3.14.12.1) on Windows XP with Cygwin (EPICS_HOST_ARCH = cygwin-x86).   To verify the installation, I was attempting to building the Example IOC application (per Section 2.2 of the Application Developer’s Guide).
Unfortunately, I am encountering the following errors upon attempting to compile:
$ make
make -C ./configure install
make[1]: Entering directory `/cygdrive/c/mytop/configure'
make -C O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
make[2]: Entering directory `/cygdrive/c/mytop/configure/O.cygwin-x86'
perl c:/EPICS/base/bin/cygwin-x86/convertRelease.pl checkRelease
make[2]: Leaving directory `/cygdrive/c/mytop/configure/O.cygwin-x86'
make[1]: Leaving directory `/cygdrive/c/mytop/configure'
make -C ./myexampleApp install
make[1]: Entering directory `/cygdrive/c/mytop/myexampleApp'
make -C ./src install
make[2]: Entering directory `/cygdrive/c/mytop/myexampleApp/src'
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering directory `/cygdrive/c/mytop/myexampleApp/src/O.cygwin-x86'
c:/EPICS/base/configure/RULES_TARGET:69: *** multiple target patterns.  Stop.
make[3]: Leaving directory `/cygdrive/c/mytop/myexampleApp/src/O.cygwin-x86'
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory `/cygdrive/c/mytop/myexampleApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/cygdrive/c/mytop/myexampleApp'
make: *** [myexampleApp.install] Error 2
Not sure if this is an indication that I have a bad EPICS base build and/or have something lacking in my environment, etc.  Any help/info/assistance will be greatly appreciated.
Thanks in advance,
Florencio Cid
RE: IOC make error Cid, Florencio A
Re: IOC make error Ron Sluiter
RE: IOC make error Mark Rivers
Prev: RE: IOC make error Cid, Florencio A
Next: RE: IOC make error Cid, Florencio A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
