1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mcaR6-12-2 build error
Date: Wed, 16 Nov 2011 17:45:41 -0800
I am trying to build mcaR6-12-2 on a RHEL5-32 machine, but getting the follow error:
make[3]: Entering directory `/afs/slac.stanford.edu/g/acctest/vol1/epics/modules/R3-14-12/mca/mcaR6-12-2/mcaApp/CanberraSrc/O.linux-x86'
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall     -std=gnu99 -DUSE_LIBNET -g `libnet-config --defines`   -m32     -g -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include                              -I/afs/slac/g/acctest/epics/modules/R3-14-12/calc/calc-R2-7-lcls3/include  -I/afs/slac/g/acctest/epics/modules/R3-14-12/sscan/sscan-R2-6-3-lcls3/include  -I/afs/slac/g/acctest/epics/modules/R3-14-12/std/std-2-8-lcls1/include  -I/afs/slac/g/acctest/epics/modules/R3-14-12/busy/busy-R1-4-lcls1/include -I/afs/slac/g/acctest/epics/modules/R3-14-12/autosave/autosave-R4-7-lcls5/include/os/Linux -I/afs/slac/g/acctest/epics/modules/R3-14-12/autosave/autosave-R4-7-lcls5/include  -I/afs/slac/g/acctest/epics/modules/R3-14-12/asyn/asyn-R4-17-RC1-lcls1/include -I/afs/slac/g/acctest/epics/base/base-R3-14-12/include/os/Linux -I/afs/slac/g/acctest/epics/bas!
 e/base-R3-14-12/include       ../nmc_comm_subs_1.c
/bin/sh: libnet-config: command not found
In file included from ../nmc_comm_subs_1.c:70:
../nmc_sys_defs.h:52:24: warning: libnet.h: No such file or directory
../nmc_sys_defs.h:53:22: warning: pcap.h: No such file or directory
../nmc_sys_defs.h:158: error: expected specifier-qualifier-list before 'libnet_t'
../nmc_sys_defs.h:188: error: expected specifier-qualifier-list before 'pcap_t'
../nmc_sys_defs.h:262: warning: 'struct pcap_pkthdr' declared inside parameter list
../nmc_sys_defs.h:262: warning: its scope is only this definition or declaration, which is probably not what you want
../nmc_comm_subs_1.c: In function 'nmc_initialize':
../nmc_comm_subs_1.c:170: error: 'PCAP_ERRBUF_SIZE' undeclared (first use in this function)
../nmc_comm_subs_1.c:170: error: (Each undeclared identifier is reported only once
../nmc_comm_subs_1.c:170: error: for each function it appears in.)
../nmc_comm_subs_1.c:171: error: storage size of 'bpfprog' isn't known
../nmc_comm_subs_1.c:172: error: 'bpf_u_int32' undeclared (first use in this function)
Do I need libnet-config?
Jingchen
RE: mcaR6-12-2 build error Mark Rivers
Prev: RE: Illegal Choice PV Chen, Xihui
Next: RE: mcaR6-12-2 build error Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
