1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Writing long strings PV in BOY
To: <[email protected]>
Date: Thu, 24 Nov 2011 00:27:17 +1100
I have a waveform record setup as array of char (to support long string) and I'm trying to write a string to it via BOY Action button. I setup a "Write PV" action in the widget but the string does not get written, so perhaps long strings are not supported in BOY actions (it works for Text Inputs).
I tried a Javascript code to convert the string to an array of char via the following code:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
var strArray = DataUtil.createIntArray(10);
var pv = widget.getPV();
var strText = "this is a test";
for(var i=0; i<strText.length; i++) {
  strArray[i] = strText.charCodeAt(i);
pv.setValue(strArray);
but the script throws an exception in BOY's console "Wrapped java.lang.Exception: Cannot handle type [I".
Is there any way in BOY to write a string to a waveform record as an array of char (support long strings)? I'm using SNS CSS 3.0.2 (Basic) for MacOSX.
Thanks in advance,
  Juan.
Juan Carlos Guzman
Software Engineer
Australia Telescope National Facility
CSIRO Astronomy and Space Science
P.O.Box 76, Epping NSW 1710, Australia
Phone: +61 2 9372 4457
Fax: +61 2 9372 4310
Email: [email protected]<mailto:[email protected]>
Re: Writing long strings PV in BOY John Hammonds
Prev: Gateway binary distribution available for RedHat 5.5 ZYCHLA Emmanuel
Next: Re: Writing long strings PV in BOY John Hammonds
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Gateway patches (CMake) Ralph Lange
