1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Nov 2011 09:57:11 -0800
Hi Mark,
Here is the info you requested:
	epics> asynReport 10
	MksuServer multiDevice:No canBlock:Yes autoConnect:Yes
	    enabled:Yes connected:Yes numberConnects 1
	    nDevices 0 nQueued 0 blocked:No
	    asynManagerLock:No synchronousLock:No
	    exceptionActive:No exceptionUsers 0 exceptionNotifys 0
	    interposeInterfaceList
	        asynOctet pinterface 0x68efa0 drvPvt 0x8f70aa8
	    interfaceList
	        asynCommon pinterface 0x68e05c drvPvt 0x8f27858
	        asynOctet pinterface 0x8f278a0 drvPvt 0x8f27858
	    Port 194.168.0.21:56789 UDP: Connected
	                    fd: 4
	    Characters written: 0
	       Characters read: 0
	Mksu multiDevice:Yes canBlock:Yes autoConnect:Yes
	    nDevices 1 nQueued 0 blocked:No
	    interfaceList
	        asynCommon pinterface 0x68f12c drvPvt 0x8f70cf8
	        asynDrvUser pinterface 0x68f204 drvPvt 0x8f70cf8
	        asynInt32 pinterface 0x68f138 drvPvt 0x8f70cf8
	        asynInt16Array pinterface 0x68f1b4 drvPvt 0x8f70cf8
	    addr 0 autoConnect Yes enabled Yes connected No exceptionActive No
	    exceptionActive No exceptionUsers 0 exceptionNotifys 0
	    blocked No
	Mksu: missing report - MksuServer
	Port: Mksu
	Parameter list 0
	Number of parameters is: 4
	Parameter 0 type=asynInt32, name=WF_TRIG_DELAY_WRITE, value is undefined
	Parameter 1 type=asynInt32, name=MOD_TRIG_DELAY_WRITE, value is undefined
	Parameter 2 type=asynInt32, name=WF_TRIG_DELAY_READ, value is undefined
	Parameter 3 type=asynInt32, name=MOD_TRIG_DELAY_READ, value is undefined
	epics>  dbpr KLYS:IN20:3130:WF_TRIG_DELAY_WRITE 10
	ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: 0
	AOFF: 0             ASG:                ASLO: 0             ASP: (nil)
	BKPT: 00            DESC: Waveform trigger delay (write)    DISA: 0
	DISP: 0             DISS: NO_ALARM      DISV: 1             DOL:CONSTANT
	DPVT: (nil)         DRVH: 0             DRVL: 0             DSET: 0x68f470
	DTYP: asynInt32     EGU:                EGUF: 0             EGUL: 0
	EOFF: 0             ESLO: 1             EVNT: 0             FLNK:CONSTANT 0
	HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
	HSV: NO_ALARM       HYST: 0             INIT: 1
	IVOA: Continue normally                 IVOV: 0             LALM: 0
	LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM
	LOLO: 0             LOPR: 0             LOW: 0              LSET: 0x8f7d120
	LSV: NO_ALARM       MDEL: 0
	MLIS: 00 00 00 00 00 00 00 00 00 00 00 00                   MLOK: 40 46 f7 08
	MLST: 0             NAME: KLYS:IN20:3130:WF_TRIG_DELAY_WRITE
	NSEV: NO_ALARM      NSTA: NO_ALARM      OIF: Full           OMOD: 0
	OMSL: supervisory   ORAW: 0             ORBV: 0             OROC: 0
	OUT:INST_IO @asyn(Mksu 0 1)WF_TRIG_DELAY_WRITE              OVAL: 0
	PACT: 0             PBRK: (nil)         PHAS: 0             PINI: NO
	PPN: (nil)          PPNR: (nil)         PREC: 0             PRIO: LOW
	PROC: 0             PUTF: 0             PVAL: 0             RBV: 0
	RDES: 0x8f2f7f8     ROFF: 0             RPRO: 0             RSET: 0x25a8e0
	RVAL: 0             SCAN: Passive       SDIS:CONSTANT       SEVR: <nil>
	SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT
	SPVT: 0x8f74b40     STAT: UDF           TIME: <undefined>   TPRO: 0
	TSE: 0              TSEL:CONSTANT       UDF: 0              VAL: 0
	epics>
File mksu.template:
	record(ao, "KLYS:$(AREA):$(LOCATION):WF_TRIG_DELAY_WRITE") {
	  field(DESC, "Waveform trigger delay (write)")
	  field(DTYP, "asynInt32")
	  field(OUT, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))WF_TRIG_DELAY_WRITE")
	  field(SCAN, "$(SCAN)")
	record(ao, "KLYS:$(AREA):$(LOCATION):MOD_TRIG_DELAY_WRITE") {
	  field(OUT, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))MOD_TRIG_DELAY_WRITE")
	  field(DESC, "Remote modulator trigger delay (write)")
	record(ai, "KLYS:$(AREA):$(LOCATION):WF_TRIG_DELAY_READ") {
	  field(INP, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))WF_TRIG_DELAY_READ")
	  field(DESC, "Waveguide trigger delay (read)")
	record(ai, "KLYS:$(AREA):$(LOCATION):MOD_TRIG_DELAY_READ") {
	  field(INP, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))MOD_TRIG_DELAY_READ")
	  field(DESC, "Remote modulator trigger delay (read)")
File mksu.substitutions:
	file ../../db/mksu.template
	pattern
	{AREA, LOCATION, PORT, CHANNEL, TIMEOUT, SCAN}
	{IN20, 3130, Mksu, 0, 1, "I/O Intr"}
Luciano
-----Original Message-----
Sent: Thursday, November 24, 2011 05:05
To: Piccoli, Luciano; [email protected]
Hi Luciano,
Can you send mksu.substitutions and whatever .template or .db files it loads?
What do you get at the IOC prompt for
asynReport 10
From: [email protected] on behalf of Piccoli, Luciano
Sent: Wed 11/23/2011 5:56 PM
To: [email protected]
Subject: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
I'm writing a simple asyn driver which I started out from the HMS example. When starting the ioc I get these messages:
        lpiccoli@cdlx22 iocMksu]$ ./st.cmd
        #! ../../bin/linux-x86/example
        dbLoadDatabase("../../dbd/example.dbd")
        example_registerRecordDeviceDriver(pdbbase)
        drvMksu_init()
        drvAsynIPPortConfigure("MksuServer", "194.168.0.21:56789 UDP", 0, 0, 1)
        initMksu("Mksu", "MksuServer")
        dbLoadTemplate("mksu.substitutions")
        iocInit()
        Starting iocInit
        ## EPICS R3.14.10-lcls1 $R3-14-10$ $2008/10/27 19:39:04$
        ## EPICS Base built Jul 15 2009
        KLYS:IN20:3130:MOD_TRIG_DELAY_READ devAsynInt32::initCommon  Link must be INST_IO
        KLYS:IN20:3130:WF_TRIG_DELAY_READ devAsynInt32::initCommon  Link must be INST_IO
        KLYS:IN20:3130:MOD_TRIG_DELAY_WRITE devAsynInt32::initCommon  Link must be INST_IO
        KLYS:IN20:3130:WF_TRIG_DELAY_WRITE devAsynInt32::initCommon  Link must be INST_IO
        epics>
It looks like something is not getting set correctly, the link type of those records should be INST_IO. Using gdb I see that they have the link type set to 0 (CONSTANT).
Am I missing something in the st.cmd file? Suggestions are welcome :)
Thank you,
Luciano
RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Mark Rivers
Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
Prev: Re: [help] degree in Computer Science/Software Engineering Pavel Masloff
Next: Re: gateway Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Mark Rivers
Next: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Mark Rivers
