1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS Base 3.14.12.2-rc1 available for testing
To: "Tim Mooney" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 29 Nov 2011 16:18:52 -0600
I have built all of synApps against 3.14.12.2-rc1 on win32-x86 and
windows-x64 as well as cygwin-x86.  All seems fine.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Tim Mooney
Sent: Tuesday, November 29, 2011 4:09 PM
To: Andrew Johnson
Cc: EPICS tech-talk
Subject: Re: EPICS Base 3.14.12.2-rc1 available for testing
Andrew,
I was able to build this on cygwin 1.7.9
(that is, uname -a yields: "CYGWIN_NT-5.1 PCBC 1.7.9(0.237/5/3)
2011-03-29 10:10 i686 Cygwin")
with only the usual "SHARED_LIBRARIES=NO, STATIC_BUILD=YES" modification
to configure/CONFIG_SITE.
Without those changes, I got the following error when the build tried to
use antelope:
   Entering directory
`/home/mooney/epics/base-3.14.12.2-rc1/src/toolsComm/flex/O.cygwin-x86'
   ../../../../bin/cygwin-x86/antelope.exe -l -d ../parse.y
   make[4]: *** [parse.c] Error 127
synApps also builds on cygwin 1.7.9 without errors against the
successful build of base,
and runs without any obvious problems in the couple of things I've
tested.
Tim
----- Original Message -----
To: "EPICS tech-talk" <[email protected]>
Sent: Monday, November 28, 2011 4:58:13 PM
Subject: EPICS Base 3.14.12.2-rc1 available for testing
The first release candidate for the 3.14.12.2 version of Base is now
available
on the website for general testing.  Links to the tarfile and Release
Notes
can be found at http://www.aps.anl.gov/epics/base/R3-14/12.php
Please report any problems you find to tech-talk.  If no major issues
are
discovered before December 12th we will release 3.14.12.2 on that date.
Thanks to everyone who has helped with this process.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
RE: EPICS Base 3.14.12.2-rc1 available for testing matthew.pearson
EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
Re: EPICS Base 3.14.12.2-rc1 available for testing Tim Mooney
Prev: Re: EPICS Base 3.14.12.2-rc1 available for testing Tim Mooney
Next: Re: [help] degree in Computer Science/Software Engineering Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS Base 3.14.12.2-rc1 available for testing matthew.pearson
