1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: finite()
Date: Wed, 30 Nov 2011 19:08:16 -0800
On 11/30/2011 01:12 PM, Andrew Johnson wrote:
Hi Till,
On 2011-11-30 Till Straumann wrote:
When building base-3-14-12-2-rc1 on uClibc
I found the following:
base is using 'finite()' which is a BSD routine
(and as such not available under uClibc).
OTOH, uClibc provides C99 and thus implements
the 'isfinite()' macro.
We already define finite() where the OS doesn't already provide it, see
src/libCom/osi/os/*/epicsMath.h.  Which OS class are you using for this
particular target?
linux. However, this is AFAIK a C-library std rather than an OS issue.
I'm using uClibc (which does not have BSD finite()).
Also it is odd that linux uses osi/os/posix/epicsMath.h but 'finite()'
is definitely not posix...
T.
- Andrew
finite() Till Straumann
Re: finite() Andrew Johnson
Prev: EPICS Contract Position - Please alert your subscribers. Ken Reed
Next: RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: finite() Andrew Johnson
Next: EPICS Contract Position - Please alert your subscribers. Ken Reed
