Hey Andrew, hi guys!
Here it is softioc -h:
D:\>softIoc -h Usage: softIoc [-D softIoc.dbd] [-h] [-S] [-a ascf] [-m macro=value,macro2=value2] [-d file.db]
[-x prefix] [st.cmd] Compiled-in path to softIoc.dbd is: 'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
By the way, in the config,site file there are no quotes at all:
INSTALL_LOCATION=d:\baseR3.14.12.1\new
Do you mean I should have put in single quotes? And, perhaps, there are some other settings before compiling that I should have set?
2011/12/5 Andrew Johnson <[email protected]>
Hi Pavel,
On 12/4/11 3:18 PM, Pavel Masloff wrote:
I don't know where this error comes from (the single
quotes). I thought running softIoc.exe is a simple way to check
the installation.
Running 'softIoc -h' may help us a little, it displays the
compiled-in path to the base/dbd/softIoc.dbd file rather than using
it and showing it to us in an error message.
Windows understands forward slashes and internally we use them
rather than back-slashes; in the softIoc output I would expect to
see back-slashes in your path to base, but forward slashes in the
/dbd/softIoc.dbd part that gets appended to point to the .dbd file,
so this error looks to me like there are single quotes in the
setting for the install location somehow.
d:\>softIoc
filename="..\dbLexRoutines.c" line number=243
Invalid argument dbRead opening file
- Andrew
-- Sincerely,
Pavel Maslov, MSc R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
- Re: [help] EPICS build no good Andrew Johnson
- [help] EPICS build no good Pavel Masloff
- RE: [help] EPICS build no good Mark Rivers
- Re: [help] EPICS build no good Pavel Masloff
BACnet for EPICS is available now. Webb, Steven B.
<2011>
2025
2026
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
