1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [building EPICS in RHEL-5 64bit] environment variables
To: [email protected]
Date: Thu, 8 Dec 2011 13:03:20 +0300
* sorry I check by running >> dev in the command line
On Thu, Dec 8, 2011 at 1:02 PM, Pavel Masloff <[email protected]> wrote:
Hello everyone!
How can I set the environment variables (PATH and EPICS_HOST_ARCH) in RHEL-5 64 bit?
I ran the EpicsHostArch.pl script (>> perl EpicsHostArch.pl), but this script only returns the variable, doesn't set anything. I check by running "dev" in the command line.
And generally, what should one do to install the epics base from scratch on a linux machine?
Thanks.
Pavel.
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Sincerely,
Pavel Maslov, MSc
[building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
Prev: [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
Next: Re: [building EPICS in RHEL-5 64bit] environment variables Alan Greer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
