1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unbalanced conditional ?
To: Dirk Zimoch <[email protected]>
Cc: EPICS <[email protected]>
Date: Thu, 8 Dec 2011 08:40:19 -0600
Interesting trick.
Did you intend to write:
	B=0
Or did you really want:
	B==0
On Dec 8, 2011, at 8:23 AM, Dirk Zimoch wrote:
> Dirk Zimoch wrote:
>> Hi all,
>> When I tried to upgrade from 3.14.8 to 3.14.12, I found that some CALC expressions are not working any more, e.g. "B=0?A"
>> In 3.14.8 and all previous versions that meant: If B is 0 then set VAL to A otherwise don't change VAL.
>> Now, I get the error message:
>> Unbalanced conditional ?: operators in CALC expression 'B=0?A'
>> Can't set "recordname.CALC" to "B=0?A"
>> Was there any good reason for this incompatible change in the CALC behavior?
>> Dirk
> By the way, the previous behavior is documented here:
> http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_Calculation#Conditional_Expression
>> (A+B)<(C+D)?E
>>    * Result is E if (A+B) < (C+D)
>>    * Result is unchanged if (A+B) >= (C+D)
> The change is not mentioned in the release notes http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
> Thus I guess the new behavior was not intended and is a bug.
> When fixing this, it is probably worth to implement as well a feature available in gcc: If the second operand is missing, it is the same as the first one.
> "A+B?:C" means "A+B?A+B:C"  but saves space and cpu cycles.
> Dirk
Re: Unbalanced conditional ? Dirk Zimoch
Prev: Re: Unbalanced conditional ? Dirk Zimoch
Next: Re: Unbalanced conditional ? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
