Also, if you want to see what is being exported in your DLL type the following command:
dumpbin /exports myLib.dll
dumpbin should be in your path if you are configured to build with the VC++ compiler.
From: [email protected] on behalf of Benjamin Franksen
Sent: Fri 12/16/2011 6:04 AM
To: Josh Stein
Cc: [email protected]; [email protected]
Subject: Re: Sequencer build errors on Windows
On Wednesday, December 07, 2011, Josh Stein wrote:
> Hello Benjamin and community,
> I am attempting to build version 2.1.3 of the sequencer on a windows
> machine. I have the MinGW tools installed along with a windows version
> of re2c. I have also already successfully built EPICS base, the example
> app and an older version of the sequencer (2.0.14) in the past.
> When executing the build from the 2.1.3 top level directory, the
> following warnings and errors are shown and the make is stopped:
> ../../../include/pv.h:75:37: warning: inline function 'pvSystem*
> pvSystem::getSystem()' declared as dllimport: attribute ignored
> [-Wattributes]
> ../../../include/pv.h:77:35: error: function 'pvStat pvSystem::attach()'
> definition is marked dllimport
> ../../../include/pv.h:78:35: error: function 'pvStat pvSystem::flush()'
I would like to pose this question to the community, especially the C++
experts.
These are the relevant lines:
class pvSystem {
public:
epicsShareFunc pvSystem( int debug = 0 );
epicsShareFunc virtual ~pvSystem();
epicsShareFunc inline pvSystem *getSystem() { return this; }
epicsShareFunc virtual pvStat attach() { return pvStatOK; }
epicsShareFunc virtual pvStat flush() { return pvStatOK; }
The code in the src/pv subsystem in the sequencer uses 'epicsShareFunc' for
C++ class methods in many places (also in the method implementations). While
it seems it has worked so far, I wonder if epicsShareFunc' is necessary here
or even intended. I looked at some EPICS base header and cpp files and found
'epicsShareFunc' is not used for C++ class methods.
So, can I just remove 'epicsShareFunc' qualifiers on class methods?
At least on my win32-x86 VM this worked fine (build & tests).
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
http://www.helmholtz-berlin.de <http://www.helmholtz-berlin.de/>
- Sequencer build errors on Windows Josh Stein
- Re: Sequencer build errors on Windows Benjamin Franksen
RE: Sequencer build errors on Windows Mark Rivers
CSS Export Waveform data John Dobbins
<2011>
2025
2026
Unbalanced conditional ? Dirk Zimoch
<2011>
2025
2026
