1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Sequencer build errors on Windows
To: "Benjamin Franksen" <[email protected]>, "Josh Stein" <[email protected]>
Cc: [email protected], [email protected]
Date: Fri, 16 Dec 2011 09:39:26 -0600
Title: Re: Sequencer build errors on Windows
Hi Ben,
I just tested the behavior of my asynPortDriver class when building dynamically on win32-x86.
If I declare the class as follows it works fine.  My testAsynPortDriverApp links and runs fine.
class epicsShareFunc asynPortDriver {
public:
If I delete the epicsShareFunc in the definition of the class then I get the following link errors when building testAsynPortDriverApp:
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox/GL   /W3 /w44355     /D_WIN32_WINNT=0x0503   /MD  /TP   -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IJ:\\epics\\devel\\ipac-2-11\\include  -IJ:\\epics\\devel\\seq-2-1-3\\include   -IH:\\epics\\base-3.14.12.2\\include\\os\\WIN32 -IH:\\epics\\base-3.14.12.2\\include       ..\\testAsynPortDriver.cpp
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release       /implib:testAsynPortDriverSupport.lib /out:testAsynPortDriverSupport.dll         testAsynPortDriver.obj      ..\\..\\..\\lib\\win32-x86-dynamic\\asyn.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\recIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\softDevIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\miscIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\rsrvIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\dbtoolsIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\asIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\dbIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\registryIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\dbStaticIoc.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\ca.lib  H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\Com.lib
   Creating library testAsynPortDriverSupport.lib and object testAsynPortDriverSupport.exp
testAsynPortDriver.obj : error LNK2001: unresolved external symbol "public: virtual void __thiscall asynPortDriver::reportParams(struct _iobuf *,int)" (?reportParams@asynPortDriver@@UAEXPAU_iobuf@@H@Z)
testAsynPortDriver.obj : error LNK2001: unresolved external symbol "public: virtual enum asynStatus __thiscall asynPortDriver::callParamCallbacks(void)" (?callParamCallbacks@asynPortDriver@@UAE?AW4asynStatus@@XZ)
testAsynPortDriver.obj : error LNK2001: unresolved external symbol "public: virtual enum asynStatus __thiscall asynPortDriver::callParamCallbacks(int)" (?callParamCallbacks@asynPortDriver@@UAE?AW4asynStatus@@H@Z)
testAsynPortDriver.obj : error LNK2001: unresolved external symbol "public: virtual enum asynStatus __thiscall asynPortDriver::callParamCallbacks(int,int)" (?callParamCallbacks@asynPortDriver@@UAE?AW4asynStatus@@HH@Z)
So it appears to be both necessary and sufficient to put the epicsShareFunc in the definition of the class itself.
Sent: Friday, December 16, 2011 7:19 AM
To: Benjamin Franksen; Josh Stein
Cc: [email protected]; [email protected]
Hi Ben,
I normally build statically on win32-x86, so I don't have a lot of experience with ensuring that the functions are visible in DLLs.  However, I know that I did make it work with the asynPortDriver class in asyn, and this is what I did:
/** Base class for asyn port drivers; handles most of the bookkeeping for writing an asyn port driver
  * with standard asyn interfaces and a parameter library. */
public:
    asynPortDriver(const char *portName, int maxAddr, int paramTableSize, int interfaceMask, int interruptMask,
                   int asynFlags, int autoConnect, int priority, int stackSize);
    virtual ~asynPortDriver();
    virtual asynStatus lock();
    virtual asynStatus unlock();
    virtual asynStatus getAddress(asynUser *pasynUser, int *address);
    virtual asynStatus readInt32(asynUser *pasynUser, epicsInt32 *value);
    virtual asynStatus writeInt32(asynUser *pasynUser, epicsInt32 value);
    virtual asynStatus readUInt32Digital(asynUser *pasynUser, epicsUInt32 *value, epicsUInt32 mask);
    virtual asynStatus writeUInt32Digital(asynUser *pasynUser, epicsUInt32 value, epicsUInt32 mask);
So it was sufficient to declare the class with epicsShareFunc, not the individual methods.  I am quite sure that my test application that uses this class linked fine when building dynamically.
From: [email protected] on behalf of Benjamin Franksen
Sent: Fri 12/16/2011 6:04 AM
To: Josh Stein
Subject: Re: Sequencer build errors on Windows
On Wednesday, December 07, 2011, Josh Stein wrote:
> Hello Benjamin and community,
>    I am attempting to build version 2.1.3 of the sequencer on a windows
> machine. I have the MinGW tools installed along with a windows version
> of re2c. I have also already successfully built EPICS base, the example
> app and an older version of the sequencer (2.0.14) in the past.
> When executing the build from the 2.1.3 top level directory, the
> following warnings and errors are shown and the make is stopped:
> ../../../include/pv.h:75:37: warning: inline function 'pvSystem*
> pvSystem::getSystem()' declared as  dllimport: attribute ignored
> [-Wattributes]
> ../../../include/pv.h:77:35: error: function 'pvStat pvSystem::attach()'
> definition is marked dllimport
> ../../../include/pv.h:78:35: error: function 'pvStat pvSystem::flush()'
I would like to pose this question to the community, especially the C++
experts.
These are the relevant lines:
class pvSystem {
public:
    epicsShareFunc pvSystem( int debug = 0 );
    epicsShareFunc virtual ~pvSystem();
    epicsShareFunc inline pvSystem *getSystem() { return this; }
    epicsShareFunc virtual pvStat attach() { return pvStatOK; }
    epicsShareFunc virtual pvStat flush() { return pvStatOK; }
The code in the src/pv subsystem in the sequencer uses 'epicsShareFunc' for
C++ class methods in many places (also in the method implementations). While
it seems it has worked so far, I wonder if epicsShareFunc' is necessary here
or even intended. I looked at some EPICS base header and cpp files and found
'epicsShareFunc' is not used for C++ class methods.
So, can I just remove 'epicsShareFunc' qualifiers on class methods?
At least on my win32-x86 VM this worked fine (build & tests).
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: Sequencer build errors on Windows Mark Rivers
Prev: Re: CSS Export Waveform data Kasemir, Kay
Next: Re: CSS Export Waveform data Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Sequencer build errors on Windows Mark Rivers
Next: Re: Sequencer build errors on Windows Benjamin Franksen
