1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [make] mingw, gnuwin32, cygwin
To: "Pavel Masloff" <[email protected]>, "EPICS Tech Talk" <[email protected]>
Date: Wed, 21 Dec 2011 11:36:06 -0600
You need to build EPICS base for each different EPICS_HOST_ARCH that you want to use.  So for Cygwin you need to set EPICS_HOST_ARCH=cygwin-x86 and build both EPICS base and the modules you want with that setting.  That will create a base/bin/cygwin-x86 and base/lib/cygwin-x86 directories, etc.  Some modules only build on certain architectures, normally because the required drivers or libraries are only supported on those architectures.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Wednesday, December 21, 2011 11:29 AM
To: EPICS Tech Talk
Subject: Re: [make] mingw, gnuwin32, cygwin
pardon me:
Can I install the Epics base using gnuwin32 and MS VS 2010 (which I did), but build applications using MinGW or cygwin?
On Wed, Dec 21, 2011 at 9:12 PM, Pavel Masloff <[email protected]> wrote:
Can I install the Epics base using gnuwin32 and MS VS 2010 (which I did), but build applications using gnuwin32 or cygwin?
Because some modules were created for linux only, therefore, for example, I can't install the s7plc driver, because it needs a program called "cat". And cat.exe I found in the cygwin bin directory.
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Sincerely,
Pavel Maslov, MSc
Re: [make] mingw, gnuwin32, cygwin Pavel Masloff
Prev: Re: [make] mingw, gnuwin32, cygwin Pavel Masloff
Next: cainfo and access Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
