1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cainfo and access
To: Pierrick Hanlet <[email protected]>
Date: Wed, 21 Dec 2011 14:38:44 -0600
Hi Pierrick,
The read/write access is determined by access security. See section 8 of the Application Developers Guide - Access Security, http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node9.html.
Strictly controlled by EPICS, no network firewalls involved.
Geoff
On 12/21/2011 1:46 PM, Pierrick Hanlet wrote:
I've not been successful in finding where this is documented.
When using caInfo on a record, one piece of infomation displayed is
read/write access to the record.  What are the different means of
setting this read/write access?  Can a network firewall setting affect
this value, or is it strictly controlled by epics?
Thank you,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 221
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
cainfo and access Pierrick Hanlet
Prev: Re: cainfo and access Andrew Johnson
Next: application build error with new sequence program S. Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
