Awesome :)
Can you also provide a patch on the known problems page of the website?
Happy Holidays,
Ernest
Sent from my iPhone
On Dec 22, 2011, at 9:38, "Janet Anderson" <[email protected]> wrote:
> I committed the change to add -I$(COMMON_DIR) to the DBFLAGS definition.
> The change will be in the next base release. Thanks.
> Janet
> Allison, Stephanie wrote:
>> Hello,
>> The following line was removed from RULES.Db sometime between epics base 3.14.8.2 and 3.14.11:
>> DBFLAGS += -I$(COMMON_DIR)
>> where
>> COMMON_DIR = ../O.Common
>> This means that a database built from a substitutions file that depends on a database already built in O.Common will fail.
>> For instance, if the Makefile looks like this:
>> DB += aabb.db
>> DB += ccdd.db
>> and the directory contains:
>> aabb.substitutions
>> ccdd.substitutions
>> and
>> ccdd.substitutions includes aabb.db, the build will now fail.
>> Can the "DBFLAGS += -I$(COMMON_DIR)" be added back to RULES.Db? If no, is there another solution to this problem? Other than creating subdirectories under Db and building in the proper order.
>> Thank you,
>> Stephanie Allison
- Re: Change to RULES.Db between 3.14.8.2 and 3.14.11 -I../O.Common no longer in include paths Andrew Johnson
- Change to RULES.Db between 3.14.8.2 and 3.14.11 -I../O.Common no longer in include paths Allison, Stephanie
- Re: Change to RULES.Db between 3.14.8.2 and 3.14.11 -I../O.Common no longer in include paths Janet Anderson
<2011>
2025
2026
<2011>
2025
2026
