1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: tech support in mcf5282_2-8
To: [email protected]
Date: Mon, 26 Dec 2011 22:20:33 -0200
Another method I have been using to implement a watchdog is routing e.g., a DMA timer output to the reset line
and use that as a watchdog.
- Till
On 12/26/2011 04:56 PM, Eric Norum wrote:
Yes, to get the code in devWatchDoc.c to work the bootloader code must be modified.  The source for the existing code is not available.
The best suggestion I can think of would be to start from some existing open source bootloader code such as "My Right Boot": uClinux -- Embedded Linux/Microcontroller Project -- ColdFire: Boot Loaders
On Dec 25, 2011, at 11:23 PM, pengshaoli wrote:
I am grateful of your immediate reply. According to your advices, is it means that the only way to make watchdog timer work is to modify the bootloader in uC5282. But as I know, the bootloader is not a open source,   can you  help me get the source code of the bootloader, or some methods to obtain it?
         If I can’t start the watchdog timer, then the driver devWatchDog.c also cannot work, right?
       Expect for your reply ! Thank you.
        Shaoli Peng
Eric Norum
[email protected]
Re: tech support in mcf5282_2-8 Eric Norum
Prev: Re: tech support in mcf5282_2-8 Eric Norum
Next: RTEMS-MVME2300 Qazi Zia-ul-Haque
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
