1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: The crash of Matlab using LabCA
To: [email protected]
Date: Thu, 29 Dec 2011 10:19:51 +0800 (CST)
Hello all
    I compiled areaDetector modules to link CCD detector. But when I run program in the Matlab by LabCA , the Matlab crash . The error code as follows. Does anyone know why?
[  0] 0x0057c422 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwfl.so+00496674 fl::sysdep::linux::unwind_stack(void const**, unsigned int, unsigned int)+000036
[  1] 0x0051d8f4 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwfl.so+00108788 fl::diag::stacktrace_base::capture(unsigned int)+000046
[  2] 0x00826d50 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00302416
[  3] 0x008274b7 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00304311
[  4] 0x00405835 /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739381
[  5] 0x00405872 /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739442
[  6] 0x0040599a /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739738
[  7] 0x03300d65 /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00204133 tcpiiu::readNotifyRequest(epicsGuard<epicsMutex>&, nciu&, netReadNotifyIO&, unsigned int, unsigned long)+000357
[  8] 0xa0ef1f38 /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+2646748984
[  3] 0x008274f4 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00304372
[  4] 0x006ce40c __kernel_rt_sigreturn+000000
[  5] 0x006ce416 __kernel_vsyscall+000002
[  6] 0x037b0e71                      /lib/i386-linux-gnu/libc.so.6+00175729 gsignal+000081
[  7] 0x037b434e                      /lib/i386-linux-gnu/libc.so.6+00189262 abort+000382
[  8] 0x0040583a /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739386
[  9] 0x00405872 /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739442
[ 10] 0x0040599a /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739738
[ 11] 0x03300d65 /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00204133 tcpiiu::readNotifyRequest(epicsGuard<epicsMutex>&, nciu&, netReadNotifyIO&, unsigned int, unsigned long)+000357
[ 12] 0x032eed95 /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00130453 cac::readNotifyRequest(epicsGuard<epicsMutex>&, nciu&, privateInterfaceForIO&, unsigned int, unsigned long, cacReadNotify&)+000197
[ 13] 0x032fbd4a /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00183626 nciu::read(epicsGuard<epicsMutex>&, unsigned int, unsigned long, cacReadNotify&, unsigned int*)+000186
[ 14] 0x0330e71a /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00259866 ca_array_get_callback+000186
[ 15] 0x07631716 /home/xxxx/shiyan/epics/src/extensions/src/labca_3_3/lib/linux-x86/libezcamt.so.0+00022294
[ 16] 0x076329b9 /home/xxxx/shiyan/epics/src/extensions/src/labca_3_3/lib/linux-x86/libezcamt.so.0+00027065 ezcaEndGroupWithReport+002345
[ 17] 0x01bd026f /home/xxxx/shiyan/epics/src/extensions/src/labca_3_3/lib/linux-x86/libmezcaglue.so.0+00012911 multi_ezca_get+001247
[ 18] 0x01b40cc8 /home/xxxx/shiyan/epics/src/extensions/src/labca_3_3/bin/linux-x86/labca/lcaGet.mexglx+00003272 mexFunction+000536
[ 19] 0x0078f8fb /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmex.so+00039163 mexRunMexFile+000109
[ 20] 0x0078c459 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmex.so+00025689
[ 21] 0x0078db69 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmex.so+00031593
[ 22] 0x001fe982 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_dispatcher.so+00432514 Mfh_file::dispatch_fh(int, mxArray_tag**, int, mxArray_tag**)+000318
[ 23] 0x00df420f /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+03146255
[ 24] 0x00df99b2 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+03168690
[ 25] 0x00dfa5fa /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+03171834
[ 26] 0x00c2ee57 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01289815
[ 27] 0x00c50054 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01425492
[ 28] 0x00c50113 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01425683
[ 29] 0x00d988c8 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+02771144
[ 30] 0x00bc3988 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00850312
[ 31] 0x00c2c6e4 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01279716
[ 32] 0x00c01634 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01103412
[ 33] 0x00c004fe /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01099006
[ 34] 0x001fe982 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_dispatcher.so+00432514 Mfh_file::dispatch_fh(int, mxArray_tag**, int, mxArray_tag**)+000318
[ 35] 0x00c06f3b /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01126203
[ 36] 0x00bb5578 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00791928
[ 37] 0x00bb9c96 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00810134
[ 38] 0x00bba3b9 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00811961
[ 39] 0x00b76cdf /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00535775 inEvalCmdWithLocalReturn+000081
[ 40] 0x00181758 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwbridge.so+00091992
[ 41] 0x00182763 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwbridge.so+00096099 mnParser+000333
[ 42] 0x0080de57 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00200279 mcrInstance::mnParser_on_interpreter_thread()+000051
[ 43] 0x00816f54 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00237396
[ 44] 0x007f5abe /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00101054
[ 45] 0x007f5ba1 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00101281
[ 46] 0x007f05ef /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00079343
[ 47] 0x0181b591 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmwuix.so+00390545
[ 48] 0x018163b8 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmwuix.so+00369592
[ 49] 0x0181e366 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmwuix.so+00402278
[ 50] 0x0625863c /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libuij.so+00251452
[ 51] 0x06254d8f /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libuij.so+00236943 svWS_ProcessPendingEvents(int, int, bool)+000595
[ 52] 0x0625820a /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libuij.so+00250378 UIJ_WS_ProcessPendingEvents(int, int)+000044
[ 53] 0x0094673f /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwservices.so+00378687 svWS_ProcessPendingEvents+000037
[ 54] 0x007f0e55 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00081493
[ 55] 0x007f117a /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00082298
[ 56] 0x007f13ab /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00082859
[ 57] 0x0024de99                /lib/i386-linux-gnu/libpthread.so.0+00024217
[ 58] 0x0385673e                      /lib/i386-linux-gnu/libc.so.6+00853822 clone+000094
Best wishes
        peng
Prev: Re: pyepics: Strategies for working with fast-changing large arrays Matt Newville
Next: Problem of "The CA server's beacon address list was empty after initialization" 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RTEMS-MVME2300 Qazi Zia-ul-Haque
