Subject: RE: Problem of "The CA server's beacon address list was empty after initialization"
To: '王林' <[email protected]>, <[email protected]>
Date: Tue, 3 Jan 2012 09:17:26 -0700
Hello Lin Wang,
At least some of the patches accommodating vxWorks 6.x can be seen at this URL.
http://bazaar.launchpad.net/~epics-core/epics-base/3.14/revision/12090
In particular I suspect that some patches to src/libCom/osi/os/vxWorks/osdSock.h, documented in the above URL, are resolving this particular issue that you are encountering when using the earlier 3.14.11 release with vxWorks 6.x.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
From: [email protected] [mailto:[email protected]] On Behalf Of ??
Sent: Thursday, December 29, 2011 6:19 AM
To: [email protected]
Subject: Problem of "The CA server's beacon address list was empty after initialization"
Hello All,
When I install EPICS 3.14.11 on RHEL4.8 for VxWorks6.8/vxWorks-ppc604_long, then create an example app, and load it to MVME5100, it will display "The CA server's beacon address list was empty after initialization?" like this:
-> </home/wanglin/vx6_8_ep11App/iocBoot/iocexample/st.cmd
## Example vxWorks startup file
cd "/home/wanglin/vx6_8_ep11App"
value = 0 = 0x0
ld < bin/vxWorks-ppc604_long/example.munch
value = 40806864 = 0x26ea9d0
dbLoadDatabase "dbd/example.dbd"
value = 0 = 0x0
example_registerRecordDeviceDriver pdbbase
value = 0 = 0x0
dbLoadTemplate "db/user.substitutions"
value = 0 = 0x0
dbLoadRecords "db/dbSubExample.db", "user=wanglin"
value = 0 = 0x0
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Dec 29 2011
value = 0 = 0x0
-> The CA server's beacon address list was empty after initialization?
I do not change any environment variables, and this problem do not happen to me for EPICS 3.14.12.1. It seems that the Bug #541358 mentioned before was fixed on EPICS 3.14.11, and the file iocinf.cpp and online_notify.c of 3.14.11 and 3.14.12.1 are the same.
So, what probably results in this problem? And how can I solve it?
Lin Wang
Prev: EPICS Collaboration Meeting Spring 2012 [Happy New Year to All] Ernest L. Williams Jr.
Next: RE: The crash of Matlab using LabCA Jeff Hill
