Subject: Re: RTEMS-MVME2300
To: Qazi Zia-ul-Haque <[email protected]>
Date: Thu, 12 Jan 2012 08:41:56 -0800
The problem is with a compile for the host machine, not a cross-compile  --  the actual cross-development target is irrelevant.  Janet's suggestion is correct.
On Jan 12, 2012, at 7:36 AM, Janet Anderson wrote:
> Your readline library may need ncurses.
> Try commenting out the "COMMANDLINE_LIBRARY=READLINE" line
> and uncommenting the "COMMANDLINE_LIBRARY=READLINE_NCURSES" line
> in base/configure/CONFIG_SITE.Common.linux-x86.
> Janet
Eric Norum
[email protected]
Re: RTEMS-MVME2300 Janet Anderson
Prev: Re: RTEMS-MVME2300 Janet Anderson
Next: RE: Does areaDetector Prosilica driver support Manta-series camera ? Davidsaver, Michael
Next: assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 王林
