1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor record support for Galil DMC-2183
To: Phillip Sorensen <[email protected]>
Cc: [email protected]
Date: Mon, 23 Jan 2012 09:25:49 -0500
On 1/23/2012 9:03 AM, Phillip Sorensen wrote:
Hello,
I see references to support for Galil motor drivers, but I have not found links to any code. Does anyone has device support (specifically for the motor record) for the Galil DMC-2183 or similar unit.
Phil Sorensen
Phil,
I believe the similar unit I have is the DMC-2140 (maybe, I'd have to check). I didn't have a reason to tie the controls to a motor record because all the position handling is controlled within the Galil code. I just set some parameters as needed and execute functions from the programmed firmware.
Wesley
Motor record support for Galil DMC-2183 Phillip Sorensen
Prev: Motor record support for Galil DMC-2183 Phillip Sorensen
Next: RE: Motor record support for Galil DMC-2183 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
